[mapguide-users] Map or Layer Preview don't show the Geometry
Alexander Fischer
deejot at gmx.de
Wed Aug 13 04:53:00 EDT 2008
So, is this error known that some CoordinateSystems are not working with
MGOS? Is there anywhere a list of these CoordinateSystems? I still hope that
I made a mistake because I have neither the time nor the knowledge to
transform the whole database into another WKT.
Kind regards,
Alex
2008/8/12 Jonio, Dennis (Aviation) <DJonio at miami-airport.com>
> Alexander,
> It looks like we share the same issue. The SRID that we use is 2236.
> I am certainly interested in how this gets resolved within MGOS. It seems
> to me though that this is a non-issue for the rest of the universe.
> My solution thus far has been to duplicate tables in Oracle and do a
> transform to a WKT that MGOS "likes". Kind'a, sort'a brutal but it is what
> it is.
> r,
> dennis
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Alexander Fischer
> *Sent:* Tuesday, August 12, 2008 5:26 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] Map or Layer Preview don't show the
> Geometry
> Hi,
> The Oracle SRID or rather the EPSG-Code is 24878.
> Now I saw, that the WKTEXT which is shown in webstudio is a little bit
> different to the WKTEXT in the MDSYS.CS_SRS - Table.
> Could this be the problem? But what can I do for this?
> Kind regards,
> Alexander Fischer
> 2008/8/12 Simon Pelicon <simon at sl-king.com>
> Hi,
> What is Oracle SRID for this geometry?
> Simon
> Alexander Fischer wrote:
> Hi,
> I'm working with MapGuide Open Source (2.0.1), MapGuide Maestro and
> King.Oracle (0.7.4).
> The Dataconnection works and I created a map and a Layer where I attached a
> Geometry with polylines.
> Also I edited the Layer style and the initial map view but when I tried the
> Preview the browser showed only the mapviewer with an empty map (no
> geometry).
> When I open the data with the webstudio there is an advice in the
> Preview-window:
> "The coordinate system is invalid.
> Could not create coordinate system forward transformation with specified
> coordinate systems.
> Exception occurred in method MgCoordinateSystem.CCoordinateSystem at line
> 380 in file ..\CoordinateSystem\CoordSys.cpp"
> My used Coordinate system is PSAD56 / UTM zone 18S (EPSG:24878)
> So I checked the WKT Code with Web Tier Test:
> PROJCS["PSAD56 / UTM zone
> 18S",GEOGCS["PSAD56",DATUM["Provisional_South_American_Datum_1956",SPHEROID["International
> 1924",6378388,297,AUTHORITY["EPSG","7022"]],AUTHORITY["EPSG","6248"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4248"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-75],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",10000000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","24878"]]
> Status: Pass
> I don't know where the problem could be. Has somebody an idea?
> I would be pleased to receive an answer.
> Kind regards, Alexander Fischer
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.138 / Virus Database: 270.6.0/1602 - Release Date: 9.8.2008 13:22
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> E-mails are automatically scanned for viruses using McAfee.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080813/0d0862ef/attachment.html
