[mapguide-users] Create layer from oracle database without
spatial data
Zac Spitzer
zac.spitzer at gmail.com
Wed Aug 13 06:39:48 EDT 2008
did your table have a pk and what was the pk column type?
z
On Wed, Aug 13, 2008 at 8:33 PM, 0uch <hwayuyu at yahoo.com.tw> wrote:
> I used mapguide studio and enterprise 2009 to create a landmark layer by
> using oracle view data, it's work , but the landmark on map can not be
> select.
> Then I tried mapguide O.S. 2.0.1 with king.Oracle , it can create layer too,
> but layer still can not be select.
> The select properties was setting correctly.
> Beside, the setting "Filter applied to data" in layer didn't work too,
> whatever i set was useless.
> Is there something wrong with my oracle data ? or some setting I missed?
> Dragan Podvezanec wrote:
>> If you use king.Oracle provider, you could use King.FDO.Class and then use
>> table without spatial data: detailed procedure is described here:
>> http://www.sl-king.com/fdooracle/KingFdoClass.htm
> View this message in context: http://www.nabble.com/Create-layer-from-oracle-database-without-spatial-data-tp18848865p18960563.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
