[mapguide-users] Install MGOS without Java
Rock Beans rockbeans at gmail.com
Wed Aug 13 15:16:28 EDT 2008
I would have to say from personal experience that Java is only needed if you
use the -withtomcat option when building. That is if you want to run JSP
pages but I prefer the PHP since MapAdmin required this anyway. One less
thing to worry about. On a side note I install with -port 80 so I can use
the default web post if available to you.
The Rock
On Wed, Aug 13, 2008 at 12:56 PM, Jeffery Jensen
<jefferyjjensen at gmail.com>wrote:
> Hello MapGuide Open Source Users,
> Is it possible to compile MapGuide Open Source without Java (J2SE)?
> Per http://mapguide.osgeo.org/2.0/docs/BuildInstallQuickStartLinux.html "MapGuide
> requires the J2SE Development Kit. Download and install the J2SE Development
> kit from http://java.sun.com/javase/downloads/index.jsp"
> Reason is my Internet Service Provider - bluehost.com - doesn't support
> Java. From my limited knowledge, it appears Java is only required if I'm
> using Tomcat or is Tomcat required for all Apached/PHP installs of MapGuide?
> Thanks for the help,
> Jeff Jensen
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080813/8ba755c1/attachment.html
