[mapguide-users] Tooltip on the marker
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Aug 14 02:58:47 EDT 2008
I found nothing wrong with the file, and the fact that it shows the
features indicates that it works correctly.
I just remembered a few things:
1. In a previous version of MapGuide, tooltips would only show on
selectable layers
2. There exists a flag called "hastooltips" in the runtime layer. I'm
not sure that you can get to it easily though.
3. The point used for the tooltip is IIRC 2 'units' in each direction.
If a map is in meters and the width is 10000 km, some pixels are not
being mapped, and cannot display tooltips.
Regards, Kenneth Skovhede, GEOGRAF A/S
gracecwl skrev:
> Hi Kenneth,
> I trace down the code, i realise that the value of ResourceID is assigned
> somewhere in the code. Therefore, i have no problem display the temporary
> layer.
> But so far, do you find out any problem with my .xml code which cause the
> tooltip cant be showed?FYI, i more my cursor almost whole piece of my
> 'marker' but stil nothing show.
> thanks for your helpfulness
> regards,
> grace
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> What do you mean you don't fill it out?
>> When you create a temporary featuresource, it gets an id like
>> "Session:xxxx-yyyy//temp.FeatureSource".
>> You must insert that name into the resourceID tag, otherwise it won't
>> show.
>> Can you display the features if there is no tooltip ?
>> If yes, keep in mind that you have to REALLY precise to hit the correct
>> pixel before the tooltip shows on a point.
>> gracecwl skrev:
>>> Hi Kenneth,
>>> I no fill out resourceID because i create new 'temporary layer' like in
>>> sheboygan example.
>>> I have try with column name but still same problem- no output.
>>> I cant try with load the layer manually, since that is a new temporary
>>> layer.However, i try the tooltip state ment in manual load without any
>>> problem.
>>> thanks and regards,
>>> grace
>>>> I assume you fill out the resourceID somehow.
>>>> Although it should work with just a string constant, have you tried with
>>>> a column name?
>>>> I'm not sure if tooltips work on data with no primary key, have you
>>>> tried it on data where there is a primary key?
>>>> If you try to load the layer manually, and open it in Studio or Maestro,
>>>> with a real data source, does that work then?
>>>> gracecwl skrev:
>>>>> Hi all,
>>>>> I try the method suggested, however, i cant get the desired output.
>>>>> May i know what happen. attached is my .xml file.
>>>>> http://www.nabble.com/file/p18937171/parcelmarker.xml parcelmarker.xml
>>>>> Farah-2 wrote:
>>>>>> Hi..!
>>>>>> It is possible to create tooltips for the pushpin markers. All u need
>>>>>> to
>>>>>> do
>>>>>> is modify your layer xml file.
>>>>>> You need to add:
>>>>>> <ToolTip> Property Name</ToolTip>
>>>>>> In your layer.xml file.
>>>>>> Regards
>>>>>> Farah
>>>>>> -----Original Message-----
>>>>>> From: Kencana [mailto:bluesky_dyx at hotmail.com]
>>>>>> Sent: Monday, November 06, 2006 8:45 AM
>>>>>> To: users at mapguide.osgeo.org
>>>>>> Subject: [mapguide-users] Tooltip on the marker
>>>>>> hi all,
>>>>>> is that possible to create tooltip for the markers(push pin) just like
>>>>>> when
>>>>>> we add a tooltip features on a layer using mapguide studio?
>>>>>> I am looking forward for the reply and thank you for the guidance..
>>>>>> Regards,
>>>>>> Kencana
>>>>>> View this message in context:
>>>>>> http://www.nabble.com/Tooltip-on-the-marker-tf2580163.html#a7192696
>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>>>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080814/0099f15e/attachment.html
