[mapguide-users] MGOS 2.0.1 Crash Issues
nclayton
nclayton at gmail.com
Thu Aug 14 11:23:58 EDT 2008
The old server is no longer in use so I can't give specifics on its specs.
The new box is:
Windows 2003 Server Standard Edition SP2
2x Intel Xeon CPU E5410 (Quad Core) 2.33GHz
IIS6 - Worker Isolation Mode (8 Worker Process Web Garden for MGOS
Application Pool)
4GB RAM
Attached is my serverconfig.ini file. I didn't make many changes to it,
other than changing the repository paths. I honestly am not 100% sure of
what effects most of the settings have on the system.
Here's a list of the currently available urls in case someone might can see
something I've done in the maps that could cause some of my problems:
http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=forrest
http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lafayette
http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lee
http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lowndes
http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=oktibbeha
http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=sunflower
http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=tunica
http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=winston
They all use the same layer styles...I just copy the layers to a new county
folder, change where the file points to and add it to a new county map. Each
county has a set of ECW raster files.
zspitzer wrote:
> can you describe the specs of the two machines ?
> had you tweaked the serverconfig.ini for the size of the machine?
> On Fri, Aug 15, 2008 at 12:22 AM, nclayton <nclayton at gmail.com> wrote:
>> yeah, I had that in place. It's odd that some of these errors only
>> started
>> happening on this new box which has a lot more horsepower than the
>> previous
>> one.
>> i'm going to keep mgos installed and try to do some testing to try to
>> figure
>> out what exactly is causing things to die on me.
>> Rock Beans wrote:
>>> That is to bad. It might have been something easy to fix. Was you
>>> installation patched to fix the Firefox 3 crash bug?
>>> The Rock
>>> On Thu, Aug 14, 2008 at 8:53 AM, nclayton <nclayton at gmail.com> wrote:
>>>> Sadly, due to the constant crashes I am having to revert all of our
>>>> maps
>>>> back
>>>> to mapguide 6.3
>>>> hopefully things will smooth out more in future releases.
>>>> View this message in context:
>>>> http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18981932.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18982544.html
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
http://www.nabble.com/file/p18983822/serverconfig.ini serverconfig.ini
View this message in context: http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18983822.html
