[mapguide-users] MGOS 2.0.1 Crash Issues
Andy Morsell amorsell at spatialgis.com
Thu Aug 14 11:53:34 EDT 2008
Hi Dave,
I'm already setup that way and still seeing issues.  The final faults are at
the mgserver.exe level rather than IIS.
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Thursday, August 14, 2008 8:51 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] MGOS 2.0.1 Crash Issues
I will forward this link again in regards to IIS and .NET.
The posting talks about issues with the Memory Pool and how it faults now
when it used to fail silently. Perhaps this has something to do with it?
http://support.microsoft.com/kb/911816
It talks about changing some settings back to the old behavior.
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: Thursday, August 14, 2008 9:45 AM
To: 'MapGuide Users Mail List'
I have similar crashing problems with 2.0.1 and also suspect raster issues,
although there are no clues in the error or event logs about this.  The
reason I suspect raster issues is that when things start to go wonky, maps
with no raster work for a little while maps with raster fail to render.
Eventually, mgserver faults and locks up.
The one common denominator for those with instability issues seems to be
running MGOS with IIS / .NET.  Is that the case for all with these problems?
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Thursday, August 14, 2008 8:37 AM
Subject: Re: [mapguide-users] MGOS 2.0.1 Crash Issues
how do they perform if you remove the rasters ?
On Fri, Aug 15, 2008 at 1:23 AM, nclayton <nclayton at gmail.com> wrote:
> The old server is no longer in use so I can't give specifics on its specs.
> The new box is:
> Windows 2003 Server Standard Edition SP2
> 2x Intel Xeon CPU E5410 (Quad Core) 2.33GHz
> IIS6 - Worker Isolation Mode (8 Worker Process Web Garden for MGOS
> Application Pool)
> 4GB RAM
> Attached is my serverconfig.ini file. I didn't make many changes to it,
> other than changing the repository paths. I honestly am not 100% sure of
> what effects most of the settings have on the system.
> Here's a list of the currently available urls in case someone might can
see
> something I've done in the maps that could cause some of my problems:
> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=forrest
> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lafayette
> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lee
> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=lowndes
> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=oktibbeha
> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=sunflower
> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=tunica
> http://www.tscmaps.com/mapguide/mapviewer/?state=ms&county=winston
> They all use the same layer styles...I just copy the layers to a new
county
> folder, change where the file points to and add it to a new county map.
Each
> county has a set of ECW raster files.
> zspitzer wrote:
>> can you describe the specs of the two machines ?
>> had you tweaked the serverconfig.ini for the size of the machine?
>> On Fri, Aug 15, 2008 at 12:22 AM, nclayton <nclayton at gmail.com> wrote:
>>> yeah, I had that in place. It's odd that some of these errors only
>>> started
>>> happening on this new box which has a lot more horsepower than the
>>> previous
>>> one.
>>> i'm going to keep mgos installed and try to do some testing to try to
>>> figure
>>> out what exactly is causing things to die on me.
>>> Rock Beans wrote:
>>>> That is to bad. It might have been something easy to fix. Was you
>>>> installation patched to fix the Firefox 3 crash bug?
>>>> The Rock
>>>> On Thu, Aug 14, 2008 at 8:53 AM, nclayton <nclayton at gmail.com> wrote:
>>>>> Sadly, due to the constant crashes I am having to revert all of our
>>>>> maps
>>>>> back
>>>>> to mapguide 6.3
>>>>> hopefully things will smooth out more in future releases.
>>>>> View this message in context:
>>>>> http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18981932.html
>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18982544.html
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
> http://www.nabble.com/file/p18983822/serverconfig.ini serverconfig.ini
http://www.nabble.com/MGOS-2.0.1-Crash-Issues-tp18943673p18983822.html
Zac Spitzer -
+61 405 847 168
