[mapguide-users] Using .NET Api to connect from a different Machine
Zac Spitzer zac.spitzer at gmail.com
Thu Aug 21 01:10:43 EDT 2008
ok, the solution is that you need to change the two settings in the
serverconfig.ini for this to work
[SiteConnectionProperties]
IpAddress = 127.0.0.1
[GeneralProperties]
MachineIp = 127.0.0.1
It's all a bit redundant, as mapguide won't start if they are
different and the server listens on all ip addresses
anyway, not just the configured address
z
On Tue, Aug 12, 2008 at 3:30 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> http://trac.osgeo.org/mapguide/ticket/659
> On Tue, Aug 12, 2008 at 3:13 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>> I have just hit this as well... using the java api with coldfusion.
>> Johann, can you file a bug?
>> z
>> On Fri, Jul 18, 2008 at 12:21 AM, Kenneth Skovhede, GEOGRAF A/S
>> <ks at geograf.dk> wrote:
>>> AFAIK, it should work then.
>>> Do you have both port 2812 and 2811 open on both machines?
>>> Since you are using .Net, you could also use the Web API.
>>> I have wrapped most of the calls in the MaestroAPI, so they appear to be
>>> native .Net classes:
>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI
>>> Regards, Kenneth Skovhede, GEOGRAF A/S
>>> Johann Nothbauer skrev:
>>>> Hi Kenneth!
>>>> Thank you for your fast answer.
>>>> I already changed the IpAdress in the "webconfig.ini" file. The
>>>> MGSiteConnection works perfectly. It's the Resource-Service that I can't
>>>> connect to (MgConnectionFailedException). Do you know which files I have to
>>>> copy for to use the Resource Service?
>>>> Thany yo for the warning, I am absolutely aware of the security issues. My
>>>> solution is designed for administrative access over local LAN only.
>>>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>>>> The file "webconfig.ini" must be changed to point to the correct server
>>>>> instead of "127.0.0.1".
>>>>> Its under the section [SiteConnectionProperties]
>>>>> IpAddress                          =127.0.0.1
>>>>> Port                               = 2812
>>>>> You might also have to copy some of the folders referenced in there,
>>>>> depending on what you want to do.
>>>>> I would not recommend doing this over the internet, because the data
>>>>> transmitted over the wire ends up in the MapGuide server process which runs
>>>>> in the "Local System Account".
>>>>>> Hi all!
>>>>>> I'm trying to use the .NET Api to establish a connection to a Mapguide
>>>>>> 2.0.1 Site without using a Web Viewer. My Application is a smart client and
>>>>>> should run on a different Machine the MapGuide Server runs on.
>>>>>> So I tried the following (in a Winforms Button_Click):
>>>>>> MapGuideApi.MgInitializeWebTier("webconfig.ini");
>>>>>> // Connect to the site.
>>>>>> MgUserInformation userInfo = new MgUserInformation("Administrator",
>>>>>> "admin");
>>>>>> MgSiteConnection siteConnection = new MgSiteConnection();
>>>>>> siteConnection.Open(userInfo);
>>>>>> MgResourceService resService =
>>>>>> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
>>>>>> This works so far, but when I try to use the Resource-Service like this:
>>>>>> MgResourceIdentifier resID = new MgResourceIdentifier("Library://");
>>>>>> MgByteReader resEnum = resService.EnumerateResources(resID, -1, "");
>>>>>> the API throws get an "OSGeo.MapGuide.MgConnectionFailedException"
>>>>>> (Message: "Cannot establish connection").
>>>>>> The same code works on the MapGuide Server Machine.
>>>>>> Is it possible to use the API to connect to a Mapguide Server on a
>>>>>> different machine? Or do I have to use the Web-API (XML) over HTTP? I can
>>>>>> change all my firewall rules, no problem.
>>>>>> Any Ideas?
>>>>>> Thanx,
>>>>>> Nothi
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
