[mapguide-users] Fusion + Oracle datasource problem
Andrew DeMerchant andrew.demerchant at gemtec.ca
Thu Aug 21 12:40:38 EDT 2008
What sort of webserver are you running? I'm using IIS5, and just enabled
compression using FlatCompression (www.flatcompression.org) and it has
dramatically sped up my initial load times for Fusion....
Andrew
gingerbbm wrote:
> Rock Beans wrote:
>> To be honest how does the data source type affect one viewer over the
>> other
> It's simply the problem that startup takes an age - if it works at all. And
> with more than ten or so layers it simply doesn't work. But it's true that
> if and when the initial load is done it all works fine. And that's the
> galling part.
	*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
