[mapguide-users] Scribble R2
Warren Medernach wmedernach at rand.com
Thu Aug 21 16:55:17 EDT 2008
I have setup the Scribble app as described, but can only get it to run
under an MGOS install?
Should I not be able to get this running on an install of MGE 2009?
Thanks
Warren Medernach
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: Thursday, August 14, 2008 2:42 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] Scribble R2
I did not build the application, I just modified it to be compatible
with MGOS 2.0 and made some other tweaks.  It was originally created by
Dennis Jonio for MGOS 1.2.  In my particular case, a client is looking
for a .NET markup tool so I was looking at Dennis' scribble application
as a good starting point since the GT redlining app is PHP and nobody
has translated it to .NET yet.  This client uses AJAX layouts or I would
probably look more closely at a Fusion / OpenLayers solution.
Personally, I prefer Fusion and it is my layout of choice, but it's not
always my decision to make.
Hopefully people will start to create new Fusion widgets and contribute
those back to the community as well.
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rock Beans
Sent: Thursday, August 14, 2008 1:07 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Scribble R2
On more of a personal level is there a reason why you didn't make this
with Fusion in mind. I have bounced the idea of using the Flexible or
Standard layouts quite a bit and the one thing that gets me is will
Fusion become standard as far as development and support. Any thoughts
on your preferences?
On Thu, Aug 14, 2008 at 2:25 PM, Andy Morsell <amorsell at spatialgis.com>
wrote:
I have not tried to integrate it into a Fusion layout, so I don't know
for sure what it would take.  I can guarantee that much will be broken
since it references the AJAX frameset objects.
Andy
Sent: Thursday, August 14, 2008 12:11 PM
Is it easy to use with Fusion layouts as well?
On Thu, Aug 14, 2008 at 11:57 AM, Andy Morsell <amorsell at spatialgis.com>
wrote:
Hi all,
I just wanted everyone to know that I have modified the Scribble
community code sample that has been available on the wiki for some time
to be compatible with MapGuide Open Source 2.0.  I have also made some
changes to the application that allow it to be dropped into any generic
task pane in any AJAX web layout.  I have also bundled all needed dll's
and have created a new zip file of the entire package.  Please see the
existing Scribble page for more information:
http://trac.osgeo.org/mapguide/wiki/CodeSamples/ASP.Net/ScribbleApp
I hope this helps others.
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080821/dc12a79f/attachment.html
