[mapguide-users] Fusion - how to set min zoom level?
Maksim Sestic max at geoinova.com
Fri Aug 22 12:11:46 EDT 2008
Andrew,
AJAX acts in the same way if you have fixed set of scales defined for a map.
Regards,
Maksim Sestic
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
DeMerchant
Sent: Friday, August 22, 2008 17:57
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Fusion - how to set min zoom level?
Thanks - but I know how to set my initial view. I just want to be able to
zoom out more, beyond that initial view. Right now, in Fusion (not in AJAX
or DWF) I can't zoom out past my initial view.
Andrew
Rodolfo Moreno wrote:
> I suposse that you are using studio 2009, well first you must define
> an extent greater that your layers.
> These values are accordign to your preference. It depends that how
> many you want to zoom out.
> Next you have that setting the map widget located in your flexible layout.
> Choose the radio button option "use custom view" and place the scale
> and the center coordinates of you preference. These values will
> determine the initial zoom.
> Regards
> Andrew DeMerchant wrote:
>> In my Fusion maps, I've just noticed that I can't zoom out beyond my
>> initial map view. The zoom slider starts out at the bottom - this
>> happens on all of my Fusion layouts. How do I set a different zoom
>> out max limit (using Studio / Maestro)?
>> Andrew
>> 	*Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Rodolfo Moreno
> CivilEng
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 2888 (20080220) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
http://www.eset.com
