[mapguide-users] SelectFeatures using SetFilter gives null
exception
Tony
techswami at hotmail.com
Fri Aug 22 19:24:21 EDT 2008
thanks
change the code still i am not getting the values result set is empty any
ideas
if i do the selection and use this code i get a value but if i am searching
it does not work
by the way if you have idea how to find the features and display them on the
map please let me know
i want to search for all the pipes that are greater than 12' and show them
on the map
Tony
MgUserInformation userInfo = new MgUserInformation(mgSessionId);
MgSiteConnection siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo);
MgResourceService resourceService =
siteConnection.CreateService(MgServiceType.ResourceService) as
MgResourceService;
MgFeatureService featureService =
siteConnection.CreateService(MgServiceType.FeatureService) as
MgFeatureService;
MgFeatureQueryOptions districtQuery = new
MgFeatureQueryOptions();
districtQuery.SetFilter("size> 12");
MgMap map = new MgMap();
map.Open(resourceService, "General Public Map");
MgLayer layer = map.GetLayers().GetItem("SD_MAINS") as MgLayer;
String layerClassName = layer.GetFeatureClassName();
String layerFeatureIdString = layer.GetFeatureSourceId();
MgResourceIdentifier districtId = new
MgResourceIdentifier(layerFeatureIdString);
MgFeatureReader featureReader =
featureService.SelectFeatures(districtId, layerClassName, districtQuery);
featureReader.ReadNext();
string ss;
ss =
featureReader.GetClassDefinition().GetDefaultGeometryPropertyName();
MgByteReader geometryBytes =
featureReader.GetGeometry("Geometry");
MgAgfReaderWriter agfReader = new MgAgfReaderWriter();
MgGeometry districtGeometry = agfReader.Read(geometryBytes);
ArrayList listEQ = new ArrayList();
while (featureReader.ReadNext())
listEQ.Add(featureReader.GetString("MATERIAL"));
string gg = listEQ[0].ToString();
Response.Write(gg);
featureReader.Close();
featureReader.Dispose();
Jackie Ng wrote:
> I see nothing indicating what feature class you are querying from. The
> fact that you are calling SelectFeatures() from the MgLayer instead of the
> MgFeatureService means that you need to new the MgMap object with the
> MgSiteConnection as indicated here:
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc9
> - Jackie
> Tony wrote:
>> Hi
>> i am using the following code to find the Pipes that are greater than
>> 12' i am getting null exeception
>> the sample code in dev guide is the same. why i am getting error
>> anyone
>> thanks
>> tony
>> MgResourceService;
>> MgFeatureService;
>> districtQuery.SetFilter("Size > 12");
>> MgLayer layer = map.GetLayers().GetItem("SD") as MgLayer;
>> layer.SelectFeatures(districtQuery);
>> //getting error here
>> MgByteReader districtGeometryData =
>> MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
>> agfReaderWriter.Read(districtGeometryData);
View this message in context: http://n2.nabble.com/SelectFeatures-using-SetFilter-gives-null-exception-tp777204p777304.html
