[mapguide-users] Lack of coordinate systems
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Sat Aug 23 05:48:39 EDT 2008
Not sure it is the same problem, but the symptoms sound similar:
http://trac.osgeo.org/mapguide/ticket/582
Regards, Kenneth Skovhede, GEOGRAF A/S
Jackie Ng skrev:
> Does that file have the correct r/w permissions?
> - Jackie
> Joanne Cook wrote:
>> Hi All,
>> I've just finished compiling the latest version of mapguide on Ubuntu
>> 8.04, and I (eventually) got through without any (obvious) failures or
>> errors. BUT, when I try and use coordinate systems in either Mapguide
>> Maestro or the webtier tests, I only have access to arbitrary XY
>> coordinate systems. With the webtier tests, if I try and ennumerate the
>> coordinate systems, the category LatLongs is visible but I get the
>> following error:
>> The coordinate system initialization failed. Could not read the category
>> from the category dictionary.
>> If I try and convert EPSG to WKT I get the following error:
>> The coordinate system conversion failed. Could not convert to WKT from
>> EPSG code: 27700. Internal error: Unable to open EPSG support file
>> gcs.csv. Try setting the GDAL_DATA environment variable to point to the
>> directory containing EPSG csv files.
>> I have found the gcs.csv file (in
>> /usr/local/mapguideopensource/server/bin/data) and have set GDAL_DATA to
>> that folder, but it doesn't seem to make any difference and I get the same
>> error message.
>> Any thoughts?
>> Many thanks
>> Jo
>> Joanne Cook
>> Senior IT Support and Development
>> Oxford Archaeology (North)
>> 01524 880212
>> http://thehumanjourney.net
>> Files attached to this email may be in ISO 26300 format (OASIS Open
>> Document Format). If you have difficulty opening them, please visit
>> http://iso26300.info for more information.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080823/77ebe6f9/attachment.html
