[mapguide-users] upload a new template for flexible layout
Chris Claydon chris.claydon at autodesk.com
Sat Aug 23 10:01:11 EDT 2008
You shouldn't need to re-start the server, but you may need to re-start Studio, or a least right-click in the template list and pick "Refresh".
In order for the template to show up in Studio, you need to create a template info XML file for it in the following location:
<MgInstallLocation>\WebServerExtensions\www\fusion\templates\mapguide
This folder should already contain similar XML files for the other templates (e.g. aqua.xml, limegold.xml, slate.xml etc.)
Chris.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Friday, August 22, 2008 4:56 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] upload a new template for flexible layout
Maybe you need to restart the MapGuide Server for the new template to be
picked up. Does your template have the xml file that describes it?
- Jackie
Rodolfo Moreno wrote:
> thanks Jackie,
> I have already copy my template to the template directory, but I can't see
> my template in MG STUDIO.
> Best Regards
> Jackie Ng wrote:
>> MapGuide does not expose template uploading services. You will have to
>> manually copy the template to the fusion template directory via
>> ftp/shared network folders/etc.
>> - Jackie
>>> Hi all, I have created a new flexible layout but and now I want to
>>> upload into MAPGUIDE SERVER, in order to appear how another layout
>>> template in STUDIO / MAESTRO. How could it be done?
>>> Thanks in advance
View this message in context: http://n2.nabble.com/upload-a-new-template-for-flexible-layout-tp759827p777269.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
