[ZS1] RE: [mapguide-users] Present postgis data with unknown coordinatesystem
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sun Aug 24 10:38:53 EDT 2008
Could you create a bug report regarding the MgDbXmlException:
http://trac.osgeo.org/mapguide/newticket
Before pressing "Save", click the "Edit Xml" button.
Select all the text and attach that to the bug report, and I will try to
fix it.
Regards, Kenneth Skovhede, GEOGRAF A/S
Andre Schoonbee skrev:
> It seems the problem is not the coordinate system
> I have loaded the postgis data using Quantum GIS and the data is in WGS84.
> So even when specifying the EPSG:34326, still does not display anything, not
> as a layer or as a map.I am using Maersto version (r3285), to create a
> standard Ajax map.
> But when I want to define the style for the towns point feature, I get an
> error:
> An error occurred while saving: The remote server returned an error: (559)
> MgDbXmlException.:
> An exception occurred in DB XM component.
> Error: XML Indexer: Parse error in document at line, 45 char22, Parser
> message: Element ' BackgroundColor' is not valid content model:
> Exception occurred in method MgResourceDefinitionManager.UpdateDocument at
> line 601 in file
> d:\buildforgeprojects\mapguide_opensource_v2.0\build_27.16\mgdev\derver\src\
> services\resource\ResourceDefinitionManage.cpp
> Andre
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Sunday, 24 August, 2008 6:38 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Present postgis data with unknown
> coordinatesystem
> try overriding the co-ordinates system picking a common one like epsg:4326
> http://spatialreference.org/ref/epsg/4326/
> you imply that individual layers work fine by themselves?
> no errors in the server error log?
> are you using fusion or the basic layouts?
> z
> On Sun, Aug 24, 2008 at 6:58 AM, Andre Schoonbee <andresch at iway.na> wrote:
>> I have data in a postgis Database. I do not know in what coordinate system
>> the data is. When I triy to render the layers on a map, I got  a blank
> map.
>> I assume the problem is the coordinate system error.
>> What should I do?
>> Andre
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080824/fa748af8/attachment.html
