[mapguide-users] Create layer from oracle database without
spatial data
0uch
hwayuyu at yahoo.com.tw
Sun Aug 24 21:50:09 EDT 2008
Finally ,
After the creation of Primary key and spatial index , the layer can work as
well as before.
I'm really appreciate for your help.
Thanks All.
T.H. Yu.
max_samart wrote:
> Hi,
> Check about the Spatial Index as well as the Primary Key ,infact you
> can try Fdo2Fdo's Oracle Toolbox for the same.
> Max !
> ----- Original Message ----
> From: 0uch <hwayuyu at yahoo.com.tw>
> To: mapguide-users at lists.osgeo.org
> Sent: Friday, August 15, 2008 5:43:42 PM
> Subject: Re: [mapguide-users] Create layer from oracle database without
> spatial data
> Thanks very much for your help here.
> We finally build the oracle spatial data.
> However, we still got the same problem: the layer whatever created by
> oracle
> view or oracle spatial data, it can not be select.
> The selection property is correct, but i cant select item ex: building ,
> landmark.....
> What should I do to make the layer selectable as the layer create by shp
> file?
> T.H. Yu.
> http://www.nabble.com/Create-layer-from-oracle-database-without-spatial-data-tp18848865p18996760.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Create-layer-from-oracle-database-without-spatial-data-tp18848865p19136814.html
