[mapguide-users] Manipulating Maps in a Session, .NET API
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Aug 26 03:18:28 EDT 2008
There is no scale in the runtime map (MgMap).
When you request that the image is rendered, you supply dpi, resolution
and either center/scale or extent.
You cannot store the scale or the center in the runtime map, you must
store it locally in your client.
Regards, Kenneth Skovhede, GEOGRAF A/S
Johann Nothbauer skrev:
> Hi All!
> Is it possible to manipulate a MgMap object via the .NET API?
> I am using the .NET API without a Viewer-Context. I'm trying to render
> a Map to a System.Windows.Form in .NET.
> I can render a Map, but can I can't change the ViewExtents or the
> ViewScale like this:
> MgMap kgMap = new MgMap();
> ... some map initialization...
> MgPoint center = kgMap.ViewCenter;  // this works well
> double viewScale = kgMap.ViewScale;
> kgMap.SetViewScale() // is impossible, no such Method
> Is this the right approach for doing such things?
> Should I use the Mapagent instead? If yes, which Method will do the
> Trick?
> cheers,
> Nothi
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
