[mapguide-users] Lack of coordinate systems
Jo Cook
j.cook at OXFORDARCH.CO.UK
Tue Aug 26 06:08:05 EDT 2008
Hi Kenneth,
It certainly seems to be the same problem, but I have tried the solution
(copying categories.txt into the both the nad directory and the data
directory and setting the PROJ_LIB environment variable to the nad
directory) but it doesn't seem to fix the problem. I have checked
permissions and this file has exactly the same permissions as everything
else in the directory. When I enumerate the coordinate system categories I
still only see the arbitrary X-Y option.
Can someone who "fixed" this issue confirm whether they copied or moved the
categories.txt file from the server directory, what the permissions are on
it once it's moved, and whether they have the GDAL_DATA and PROJ_LIB
environment variables set when they start the server. I am starting mgserver
as root- is this likely to be part of the problem?
Thanks
Jo
Kenneth Skovhede, GEOGRAF A/S wrote:
> Not sure it is the same problem, but the symptoms sound similar:
> http://trac.osgeo.org/mapguide/ticket/582
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Jackie Ng skrev:
>> Does that file have the correct r/w permissions?
>> - Jackie
>> Joanne Cook wrote:
>>> Hi All,
>>> I've just finished compiling the latest version of mapguide on Ubuntu
>>> 8.04, and I (eventually) got through without any (obvious) failures or
>>> errors. BUT, when I try and use coordinate systems in either Mapguide
>>> Maestro or the webtier tests, I only have access to arbitrary XY
>>> coordinate systems. With the webtier tests, if I try and ennumerate the
>>> coordinate systems, the category LatLongs is visible but I get the
>>> following error:
>>> The coordinate system initialization failed. Could not read the category
>>> from the category dictionary.
>>> If I try and convert EPSG to WKT I get the following error:
>>> The coordinate system conversion failed. Could not convert to WKT from
>>> EPSG code: 27700. Internal error: Unable to open EPSG support file
>>> gcs.csv. Try setting the GDAL_DATA environment variable to point to the
>>> directory containing EPSG csv files.
>>> I have found the gcs.csv file (in
>>> /usr/local/mapguideopensource/server/bin/data) and have set GDAL_DATA to
>>> that folder, but it doesn't seem to make any difference and I get the
>>> same
>>> error message.
>>> Any thoughts?
>>> Many thanks
>>> Jo
>>> Joanne Cook
>>> Senior IT Support and Development
>>> Oxford Archaeology (North)
>>> 01524 880212
>>> http://thehumanjourney.net
>>> Files attached to this email may be in ISO 26300 format (OASIS Open
>>> Document Format). If you have difficulty opening them, please visit
>>> http://iso26300.info for more information.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Lack-of-coordinate-systems-tp19109875p19158773.html
