[mapguide-users] Is there a file size limit?
BradM
masonb at dfo-mpo.gc.ca
Tue Aug 26 17:08:15 EDT 2008
We do have a generalized layer that we display to about 1:250,000 and then we
switch to the watershed atlas. The atlas is then available for the larger
scales. The line style is a simple blue line. We didn't want to re-process
the atlas because it would take a lot of work and it worked fine with
MGE2008. But I suppose we could generalize it and cut it up into many parts
if needed.
thanks
brad
Martin Morrison wrote:
> Are you using a bunch of small segments for lines or a long polyline
> with multiple vertexes? Can you generalize the data for when you are
> zoomed out and then switch layers to one with more detail as you zoom
> in?
> Martin
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of BradM
> Sent: Tuesday, August 26, 2008 4:48 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Is there a file size limit?
> Yes we turned all other layers off and even tried removing them
> completely.
> This is a line layer and double line layer for rivers and polygon layer
> for
> lakes. So it is a mix of several layers. Yes there is labelling but we
> turned it off to try to speed things up. We just increased the cache
> size
> in the ini file and this seems to have helped with speed but it is still
> very slow when we select a stream to get its properties. I don't know
> which
> line style is being used, I will have to get back to you on that
> question.
> thanks
> brad
> Traian Stanev wrote:
>> There is no size limit. To make sure this layer is to blame, did you
> turn
>> off all other layers when viewing the map? Also, is this a line layer
> or a
>> polygons layer. What line style or polygon style is it using to
> render? Is
>> there labeling?
>> Traian
>>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>>> Sent: Tuesday, August 26, 2008 4:15 PM
>>> Subject: [mapguide-users] Is there a file size limit?
>>> After upgrading from MGE2008 to MGE2009 we have noticed a severe
>>> decline in
>>> map rendering speed for our hydrology layer for British Columbia.
> The
>>> sdf
>>> file is about 800megs and is in the map repository. Is there a file
>>> size
>>> limit? We have tried to optimize the server to improve speeds with
> no
>>> success. Any suggestions welcomed.
>>> View this message in context: http://www.nabble.com/Is-there-a-file-
>>> size-limit--tp19169522p19169522.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Is-there-a-file-size-limit--tp19169522p19170081.ht
> ml
View this message in context: http://www.nabble.com/Is-there-a-file-size-limit--tp19169522p19170435.html
