[mapguide-users] invokeURL FUSION only works fine from mgstudio
Chris Claydon chris.claydon at autodesk.com
Tue Aug 26 22:50:59 EDT 2008
Can you save your flexible web layout as XML and send it to us? (MG Studio has a function to save as XML) I'd like to try to reproduce the problem.
Chris.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rodolfo Moreno
Sent: Tuesday, August 26, 2008 4:33 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] invokeURL FUSION only works fine from mgstudio
I am using an invokeURL widget. When my map is launched from mapguide studio
2009 the SESSIONID and MAPNAME parameters are sent without errors to the
mapguide server, however when the map is launched from the index.html
directly these parameters are sent twice.
Request["MAPNAME"] = MyMap48b483ff318e5,MyMap48b483ff318e5
is it a issue of fusion?
Regards
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/invokeURL-FUSION-only-works-fine-from-mgstudio-tp785418p785418.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
