[mapguide-users] Is there a file size limit?
Zac Spitzer
zac.spitzer at gmail.com
Tue Aug 26 23:43:38 EDT 2008
are you using any filters on your layer? is there only a single layer
off each the feature source?
z
On Wed, Aug 27, 2008 at 9:54 AM, Traian Stanev
<traian.stanev at autodesk.com> wrote:
> OF, if it's solid line, then it's not immediately clear to me why it would be slower, at least from rendering perspective. One thing you could try is switch the renderer from AGG to GD in the serverconfig file to see if that makes any difference.
> Traian
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>> bounces at lists.osgeo.org] On Behalf Of BradM
>> Sent: Tuesday, August 26, 2008 5:08 PM
>> To: mapguide-users at lists.osgeo.org
>> Subject: RE: [mapguide-users] Is there a file size limit?
>> We do have a generalized layer that we display to about 1:250,000 and
>> then we
>> switch to the watershed atlas. The atlas is then available for the
>> larger
>> scales. The line style is a simple blue line. We didn't want to re-
>> process
>> the atlas because it would take a lot of work and it worked fine with
>> MGE2008. But I suppose we could generalize it and cut it up into many
>> parts
>> if needed.
>> thanks
>> brad
>> Martin Morrison wrote:
>> > Are you using a bunch of small segments for lines or a long polyline
>> > with multiple vertexes? Can you generalize the data for when you are
>> > zoomed out and then switch layers to one with more detail as you zoom
>> > in?
>> > Martin
>> > [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of BradM
>> > Sent: Tuesday, August 26, 2008 4:48 PM
>> > Yes we turned all other layers off and even tried removing them
>> > completely.
>> > This is a line layer and double line layer for rivers and polygon
>> layer
>> > for
>> > lakes. So it is a mix of several layers. Yes there is labelling but
>> we
>> > turned it off to try to speed things up. We just increased the cache
>> > size
>> > in the ini file and this seems to have helped with speed but it is
>> still
>> > very slow when we select a stream to get its properties. I don't
>> know
>> > which
>> > line style is being used, I will have to get back to you on that
>> > question.
>> > thanks
>> > brad
>> > Traian Stanev wrote:
>> >> There is no size limit. To make sure this layer is to blame, did you
>> > turn
>> >> off all other layers when viewing the map? Also, is this a line
>> layer
>> > or a
>> >> polygons layer. What line style or polygon style is it using to
>> > render? Is
>> >> there labeling?
>> >> Traian
>> users-
>> >>> Sent: Tuesday, August 26, 2008 4:15 PM
>> >>> Subject: [mapguide-users] Is there a file size limit?
>> >>> After upgrading from MGE2008 to MGE2009 we have noticed a severe
>> >>> decline in
>> >>> map rendering speed for our hydrology layer for British Columbia.
>> > The
>> >>> sdf
>> >>> file is about 800megs and is in the map repository. Is there a file
>> >>> size
>> >>> limit? We have tried to optimize the server to improve speeds with
>> > no
>> >>> success. Any suggestions welcomed.
>> >>> View this message in context: http://www.nabble.com/Is-there-a-
>> file-
>> >>> size-limit--tp19169522p19169522.html
>> >>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> >>> _______________________________________________
>> >>> mapguide-users mailing list
>> >>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> > http://www.nabble.com/Is-there-a-file-size-limit--
>> tp19169522p19170081.ht
>> > ml
>> View this message in context: http://www.nabble.com/Is-there-a-file-
>> size-limit--tp19169522p19170435.html
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
