[mapguide-users] Continued MGOS 2.0.1 Crashes
Andy Morsell
amorsell at spatialgis.com
Wed Aug 27 12:40:09 EDT 2008
Here is some more feedback to the developers on my MGOS 2.0.1 crashes /
lockups. This is on IIS5 on Windows 2000 Server with the .NET web
extensions. This server previously ran all prior versions of MGOS with the
same site data. This problem occurs every two to three days with moderate
load on the server (they're just demo sites). The data being accessed
includes a couple of raster images (one 300 MB ECW and one 300 MB MrSID) and
multiple WMS requests. When the server locks up, there is an error dialog
on the console stating that mgserver.exe has faulted. When an MGOS layout
is attempted to be accessed, this is returned:
An exception occurred in DB XML component. Error: Out of memory in
NsSAX2Reader parse File: ..\src\dbxml\nodeStore\NsSAX2Reader.cpp Line: 346An
exception occurred in DB XML component. Error: Out of memory in NsSAX2Reader
parse File: ..\src\dbxml\nodeStore\NsSAX2Reader.cpp Line: 346 Exception
occurred in method MgResourceDefinitionManager.PutDocument at line 554 in
file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src
\services\resource\ResourceDefinitionManager.cpp
And task manager shows the mgserver process with one CPU pegged at 100% and
consuming a large amount of RAM. The MapGuide server service cannot be
restarted via the standard methods and I must use something like pskill.
My TempPath parameter in serverconfig.ini points to a location with plenty
of free space.
The error.log file has a few repitive entries. The first one related to a
raster layer and the second to Fusion:
<2008-08-24T14:06:42> Fusion Viewer 75.84.139.63 Anonymous
Error: Failed to stylize layer: Spokane_County_Hillshade
Out of memory.
bad allocation
StackTrace:
- MgMappingUtil.StylizeLayers line 775 file
\services\mapping\MappingUtil.cpp Failed to stylize layer:
Out of memory.
bad allocation
<2008-08-24T17:12:03> Fusion Viewer 75.84.139.63 Anonymous
Error: Invalid argument(s):
The value cannot be less than or equal to zero.
StackTrace:
- MgRenderingServiceHandler.ProcessOperation line 83 file
\services\rendering\RenderingServiceHandler.cpp
- MgOpQueryFeatures.Execute line 125 file
\services\rendering\OpQueryFeatures.cpp
- MgServerRenderingService.QueryFeatures line 652 file
\services\rendering\ServerRenderingService.cpp
- MgServerRenderingService.RenderForSelection line 1041 file
\services\rendering\ServerRenderingService.cpp Invalid
argument(s):
<2008-08-24T17:16:34> Fusion Viewer 75.84.139.63 Anonymous
Error: Out of memory.
bad allocation
StackTrace:
- MgOpRenderMap.Execute line 263 file
\services\rendering\OpRenderMap.cpp
- MgServerRenderingService.RenderMap line 549 file
\services\rendering\ServerRenderingService.cpp Out of memory.
bad allocation
I hope this information helps.
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080827/8dc3467d/attachment.html
