[mapguide-users] MGE2009 crashing
Andy Morsell amorsell at spatialgis.com
Thu Aug 28 20:40:36 EDT 2008
Brad,
No, I am not aware of a patch for MGE.  Perhaps the Autodesk folks can chime
in here.  If there is a patch forthcoming for MGE2009, we should see
something on the MGOS side first, however.......
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of BradM
Sent: Thursday, August 28, 2008 3:42 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] MGE2009 crashing
Hi Andy, I heard that there is a patch or fix coming out for MGE2009.  Are
you aware of it or when it may come?
thanks
Andy Morsell wrote:
> So it looks like it's not web server or web extension specific.  I agree
> since whenever I see problem there is a Windows error dialog on the
> console
> reporting mgserver.exe as the faulting module.  The only commonality here
> is
> that everyone reporting this problem is running Windows.  Is anyone
> running
> MGOS 2.0.1 on Linux in a production environment seeing these same
> problems?
> By the way Zac, your openlayers demo is very cool.
> Andy
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Thursday, August 28, 2008 8:40 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] MGE2009 crashing
> server is down it's the  /. effect
> I am seeing this on XP/2003 with Apache and php / java as well. I think
> the
> problem
> lies in the mgserver side rather than anything in the webtier.
> 2.0.1 is still not stable enough, using tiled maps helped a lot, but it's
> still a gamble.
> I ended up developing a workaround which involves bypassing the MapGuide
> server
> altogether for tiled maps, using openlayers and a static copy of a fully
> seeded tile
> cache.
> here's a demo, that's just plain old apache
> http://ennoble.dreamhosters.com/maps/tm-kl/
> z
> On Fri, Aug 29, 2008 at 1:05 AM, BradM <masonb at dfo-mpo.gc.ca> wrote:
> We are using Apache.  The watershed atlas and its tool tips seem to be
> causing the server to choke:
> http://204.244.79.12/mapguide2009/SHIM/Shim.php
> Andy Morsell wrote:
>> That's very similar to the thread I started yesterday regarding crashing
>> problems I'm having with MGOS 2.0.1.  I am seeing the same error messages
>> in
>> the log files.  Are you using Windows Server / IIS / .NET?
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> www.SpatialGIS.com
>> Sent: Thursday, August 28, 2008 7:53 AM
>> Subject: [mapguide-users] MGE2009 crashing
>> Our server crashed again last night.   Is more ram a possible solution?
>> We
>> did not have this problem with MGE2008
>> thanks
>> <2008-08-27T14:36:56>    Anonymous
>>  Error: Out of memory.
>>         bad allocation
>>  StackTrace:
>>   - MgRenderingServiceHandler.ProcessOperation line 83 file
d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\
>> rendering\RenderingServiceHandler.cpp
>>   - MgOpQueryFeatures.Execute line 125 file
>> rendering\OpQueryFeatures.cpp
>>   - MgServerRenderingService.QueryFeatures line 647 file
>> rendering\ServerRenderingService.cpp
>>   - MgServerRenderingService.RenderForSelection line 1252 file
>> Out of memory.
>> bad allocation
>> View this message in context:
>> http://www.nabble.com/MGE2009-crashing-tp19202309p19202309.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/MGE2009-crashing-tp19202309p19202572.html
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
http://www.nabble.com/MGE2009-crashing-tp19202309p19210635.html
