[mapguide-users] LatLong to UTM
Don MacGregor sir_sunkee at yahoo.ca
Fri Aug 29 15:39:37 EDT 2008
PHP,  IIS 6 on Windows Server2003 SP2.
Dave Wilson-3 wrote:
> What API are you using? Not that it should make much of a difference other
> than possible rounding error.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Don MacGregor
> Sent: Friday, August 29, 2008 12:04 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] LatLong to UTM
> I am using MapGuide Open Source 2.0.1.
>> Using MGE2009 I get the correct answer for your Zone 12 example. The
>> difference may be related to PROJ4 vs Mentor being used in MGOS. Which
>> version of MGOS?
>> Dave
>> MacGregor
>> Sent: Friday, August 29, 2008 10:46 AM
>> Hi Dave,
>> You are right the point was in Zone 19.
>> But even when I enter a zone 12 point e.g. Long -110.85980508, Lat
>> 55.50472355 then I got N:6151000.496561 E:508855.1818729 as a result and
>> the
>> point should be N:6150967.822 E:508855.135.
>> Many thanks for you time.
>>> I could be completely off here, but -71,42 is in North Eastern United
>>> States which is definitely not Zone 12.
>>> Dave
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Don C.
>>> MacGregor
>>> Sent: Friday, August 29, 2008 8:32 AM
>>> Subject: [mapguide-users] LatLong to UTM
>>> Hi folks,
>>> I am trying to write a script that can convert LatLong point to UTM.
>>> Although the script its working but I am not getting the right results.
>>> Below please find my script.
>>>     $wktProj =
>>> 'PROJCS["NAD_1983_UTM_Zone_12N",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],
> PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],
> PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],
> PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-111.0],PARAMETER["Scale_Factor",0.99965242],
> PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]';
>>>         $coordSysFactory = new MgCoordinateSystemFactory();
>>>         $coordSysProj = $coordSysFactory->Create($wktProj);
>>>         $geometryFactory = new MgGeometryFactory();
>>>         $xProj = -71.061342;
>>>         $yProj= 42.353966647205;
>>>         $coordinate = $geometryFactory->CreateCoordinateXY($xProj,
>>> $yProj);
>>>         $convertedCoordinate =
>>> $coordSysProj->ConvertFromLonLat($coordinate);
>>>         $xConv = $convertedCoordinate->GetX();
>>>         $yConv = $convertedCoordinate->GetY();
>>> I am getting (434696.747152, 6017918.57788) and the correct porjected
>>> point is (434700.172, 6017603.009).
>>> Any help in this regard would be highly appreciated.
>>> Thanks
>>> ________________________________
>>> [http://us.i1.yimg.com/us.yimg.com/i/ca/iotg_search.jpg]Yahoo! Canada
>>> Toolbar : Search from anywhere on the web and bookmark your favourite
>>> sites. Download it now! <http://ca.toolbar.yahoo.com/>
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/LatLong-to-UTM-tp19221187p19223605.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> http://www.nabble.com/LatLong-to-UTM-tp19221187p19224803.html
View this message in context: http://www.nabble.com/LatLong-to-UTM-tp19221187p19226222.html
