[mapguide-users] How to create filled polygon from data file?
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Dec 1 08:03:04 EST 2008
I'm pretty sure you can't do this through Studio (hapilly corrected).
It would be straightforward through code.
Simply create the WKT for the polygons like "POLYGON((" + points string
and insert this with the Fdo Insert/Update command (avalible from the
MapGuide API).
Regards, Kenneth Skovhede, GEOGRAF A/S
jamesdudden skrev:
> Hi,
> Is it possible to create a filled polygon from data? - The data has a centre
> point (longitute/latitude) and a string of points (longitute/latitude) that
> make up the shape outline.
> Would this be done in MGStudio or would it need to be done in code.
> Any help or advie would be appreciated.
> Regards
> James
> Straightforward solutions to take care of your business
> http://www.software-matters.co.uk Software Matters
