[mapguide-users] XML Parser error for Feature Sources
cagray colin.gray at 1spatial.com
Mon Dec 1 11:53:03 EST 2008
I tried your example and I always get an error of:
Object reference not set to an instance of an object.
when I do:
 fs.Parameter["DefaultFilePath"] = "C:\my.shp";
or other similar attempts for other providers. If I take this line out it
creates the resource no problem. Do you know why this would happen?
Also I tried to download the help (MaestroAPI.chm) off the website but none
of the help links work. Have I done something daft?
Any help is appreciated.
Colin
Kenneth Skovhede, GEOGRAF A/S wrote:
> Yes, you can do just that.
> Look in the Maestro source code to see how it's done.
> The files "ResourceEditors/ResourceEditorBase.cs"  and
> "ResourceEditors/ResourceEditorGeneric.cs" shows it.
> Some more customized versions are avalible in eg
> "FeatureSourceEditorSDF.cs"
> Basically you can do:
>     MaestroAPI.ServerConnectionI con; //You must initialize this, see
> the developer docs
>     MaestroAPI.FeatureSource fs = new MaestroAPI.FeatureSource();
>     fs.Provider = "OSGeo.SHP.3.1";
>     con.SaveResourceAs(fs, new MaestroAPI.ResourceIdentifier("my fs",
> OSGeo.MapGuide.MaestroAPI.ResourceTypes.FeatureSource));
> As for your actual problem, does the server error log show anything?
> C:\program files\Mapguideopensource2.0\server\logs\error.log
> Regards, Kenneth Skovhede, GEOGRAF A/S
> cagray skrev:
>> Thanks for the reply. Unfortunately that did not solve my problem and I
>> got
>> the same error. Is there anything else I could try?
>> I was not aware you could do this without generating/manipulating the
>> xml.
>> My web tool has to fully control setting up data sources. So the user
>> selects a provider and then fills in the connection details. I then need
>> to
>> create a new data source from this to be stored in mapguide. Can you do
>> this
>> using the Meastro API alone?
>>> I believe the problem is the .Net UTF-8 Encoder prefixes an UTF-8 BOM,
>>> which causes problems in the Xml parser:
>>> http://trac.osgeo.org/mapguide/ticket/233
>>> You can try to create the UTF-8 encoder with:
>>> UTF8Encoding utf8 = new UTF8Encoding(false);
>>> And see if the problem goes away.
>>> Alternatively you can use the MaestroAPI instead of messing with the raw
>>> Xml:
>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/XML-Parser-error-for-Feature-Sources-tp20770245p20774513.html
