[mapguide-users] SV: Runtime map problem
padmini godavarthi
godavarthi.padmini at gmail.com
Wed Dec 3 04:37:03 EST 2008
Thanks for u r reply.
I tried this code but i got an error that
Server Error in '/maestro' Application.
HTTP Error 400 - Bad Request.
Version Information: ASP.NET Development Server 8.0.0.0
my code was
Dim host As New Uri("http://localhost/mapguide/mapagent/mapagent.fcgi")
Dim conn As New HttpServerConnection(host, "Administrator", "admin",
"en", True)
'You have to change the string below to point at a valid WebLayout
Dim weblayout As WebLayout = conn.GetWebLayout("Library://Filebased
data/Layout/layout.WebLayout")
Dim mapdefinition As MapDefinition =
conn.GetMapDefinition(weblayout.Map.ResourceId)
weblayout.Map.InitialView = New MapViewType()
weblayout.Map.InitialView.Scale = 2000 'Zoom to 1:2000
weblayout.Map.InitialView.CenterX = (mapdefinition.Extents.MaxX -
mapdefinition.Extents.MinX) + mapdefinition.Extents.MinX
weblayout.Map.InitialView.CenterY = (mapdefinition.Extents.MaxY -
mapdefinition.Extents.MinX) + mapdefinition.Extents.MinY
Dim tempid As ResourceIdentifier = New ResourceIdentifier("layout",
OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, conn.SessionID)
Response.Redirect("/mapguide/ajaxviewer/WEBLAYOUT=" &
Server.UrlEncode(tempid)
joscsu wrote:
> Or this:
> System.Guid.NewGuid().ToString()
> ----- Ursprungligt meddelande ----
> Från: Maksim Sestic <max at geoinova.com>
> Till: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> Skickat: tisdag 2 december 2008 16:49:21
> Ämne: RE: [mapguide-users] Runtime map problem
> Try this:
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
> godavarthi
> Sent: Tuesday, December 02, 2008 15:35
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] Runtime map problem
> Hi,
> Thanku very much for ur help
> i tried this code
> but i got an error in the line
> Dim tempid as ResourceIdentifier = new ResourceIdentifier(Guid.NewGuid(),
> OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, con.SessionID)
> because of this Guid.NewGuid()
> 1) Actually what is this?
> 2) Which paramater we have to pass in this place instead of Guid.NewGuid()
> Regards,
> Padmini
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> I forgot to save the weblayout in the code below :(
>> Updated version is:
>> 'Setup connection
>> Dim host As New
>> "en", True)
>> 'You have to change the string below to point at a valid WebLayout Dim
>> weblayout as WebLayout =
>> con.GetWebLayout("Library://mylayout.WebLayout")
>> Dim mapdefinition as MapDefinition =
>> con.GetMapDefinition(weblayout.Map.ResourceId)
>> 'Modify the initial view of the weblayout weblayout.Map.InitialView =
>> new MapViewType() weblayout.Map.InitialView.Scale = 2000 'Zoom to
>> 1:2000 weblayout.Map.InitialView.CenterX = (mapdefinition.Extents.MaxX
>> 'Obtain a unique session based id for the temporary weblayout (which
>> is a copy of an existing WebLayout) Dim tempid as ResourceIdentifier =
>> 'Save the layout, otherwise you can't reference it
>> con.SaveResourceAs(weblayout, tempid)
>> 'Open the viewer, and use the temporary layout, since the map only
>> exists in the 'current session, we must use that session, and NOT
>> supply username/password
>> 'BEWARE: The session belongs to the Administrator account, so the user
>> gets full access to MapGuide (delete, modify, etc.)
>> Response.Redirect("/mapguide/ajaxviewer/?WEBLAYOUT=" &
>> Server.UrlEncode(tempid) & "&SESSION=" &
>> Server.UrlEncode(con.SessionID))
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> Kenneth Skovhede, GEOGRAF A/S skrev:
>>> To build a map, you must have all the components:
>>> 1. FeatureSource, references data
>>> 2. LayerDefinition, references a FeatureSource 3. MapDefinition,
>>> references multiple LayerDefinitions 4. WebLayout, references a
>>> MapDefinition
>>> All these items must be in a repository (either Library or Session),
>>> otherwise they can't be referenced.
>>> When you write that you want to "create a WebLayout programatically",
>>> do you want to create ALL the above items, or do you have layers and
>>> featuresources?
>>> (1) If you want to generate a WebLayout ResourceID, you should use:
>>> Dim res As New ResourceIdentifier("Filebased data/Maps/mapdata",
>>> ResourceTypes.WebLayout)
>>> If you want to read the name of an existing MapDefinition from
>>> another layout, you must do:
>>> Dim weblayout as WebLayout =
>>> Dim res as String = webLayout.Map.ResourceId
>>> (2) I don't understand the question.
>>> (3) The MapDefinition is an Xml document. Inside, it references
>>> layers, which references featuresources, as described above. It is
>>> very slow to do this, so when you open a map in the browser, the xml
>>> is transformed into a binary object. This object contains all the
>>> info from the MapDefinition and some info from the layers and
>>> featuresources.
>>> You need to know this, because if you try to toggle layer visibility
>>> in the MapDefinition, nothing happens. In short, the Runtime Map is a
>>> binary object that you can manipulate using the MapGuide (and
>>> Maestro)-API, and it only works for a displayed map.
>>> Upon startup, the Runtime Map is identical to the MapDefinition it
>>> was created from.
>>> A short example of using an existing WebLayout:
>>> Dim host As New
>>> "en", True)
>>> weblayout.Map.InitialView = new MapViewType()
>>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinY Dim tempid
>>> Server.UrlEncode(tempid) & "&USERNAME=Anonymous&PASSWORD=")
>>> padmini godavarthi skrev:
>>>> Hi,
>>>> actually i wrote the code as
>>>> Dim host As New
>>>> "admin", "en", True)
>>>> data/Maps/mapdata",
>>>> ResourceTypes.MapDefinition)
>>>> Dim mapId As String = res.ResourceId
>>>> with that i got the map resource id.
>>>> But actually to run the application the url in the browser must be
>>>> like
>>>> http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fF
>>>> ilebased+data%2fLayout%2flayout.WebLayout
>>>> 1) How can i get this weblayout (like
>>>> Library%3a%2f%2fFilebased+data%2fLayout%2flayout.WebLayout)
>>>> programmetically
>>>> 2) I want to redirect to the ajax viewer sample application through
>>>> asp.net (like given by u )
>>>> Response.Redirect("/mapguide/ajaxviewer/?WEBLAYOUT=...resourceId
>>>> for
>>>> your WebLayout...&USERNAME=Anonymous&PASSWORD=");
>>>> 3) Can u plz tell me the purpose of runtime map (actualli iam in
>>>> configusing
>>>> state)
>>>>> Instead of re-posting the original question, could you try to
>>>>> explain what parts of my previous reply that are unclear or wrong?
>>>>> http://www.nabble.com/How-to-Load-Runtime-map-in-mapviewerajax-to20
>>>>> 704038.html#a20769349
>>>>>> Hi ,
>>>>>> iam using mapguide open source 2.0( with .Net 2.0 + IIS 5.1) Iam
>>>>>> using dotnet viewer sample while running the application i
>>>>>> observed that the layout path given in the application.
>>>>>> as
>>>>>> String webLayout =
>>>>>> "Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout";
>>>>>> it works but now i want to create this weblayout in run time (by
>>>>>> code)
>>>>>> using mapguide maestro api
>>>>>> for this purpose i followed the link
>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/Run
>>>>>> timeMap
>>>>>> but i didnt get any out.
>>>>>> can u plz tell me
>>>>>> 1) how to create this weblayout in run time
>>>>>> 2) How it will works
>>>>>> If u know this plz tell me the procedure.
>>>>>> Regards,
>>>>>> Padmini.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Runtime-map-problem-tp20789983p20793385.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> __________ Information from ESET NOD32 Antivirus, version of virus
> signature
> database 3658 (20081202) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
> __________________________________________________________
> Låna pengar utan säkerhet. Jämför vilkor online hos Kelkoo.
> http://www.kelkoo.se/c-100390123-lan-utan-sakerhet.html?partnerId=96915014
View this message in context: http://www.nabble.com/Runtime-map-problem-tp20789983p20809622.html
