[mapguide-users] SV: Runtime map problem
padmini godavarthi godavarthi.padmini at gmail.com
Wed Dec 3 06:01:22 EST 2008
Thanks .its working fine now.
To build a map, you must have all the components:
1. FeatureSource, references data
2. LayerDefinition, references a FeatureSource
3. MapDefinition, references multiple LayerDefinitions
4. WebLayout, references a MapDefinition
All these items must be in a repository (either Library or Session)
I know the procedure to create it in mapguide maestro.
   1) Now my problem was  i want to create   ALL the above items
programmetically (my input is only a shape file)  byusing maestro dll.
If u know this plz help me
Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> I wrote a follow up, with corrected code.
> You are using the initial one, and you are missing a "?" mark in the
> redirect URL.
> Try to use the updated version, and beware of the question mark in the
> Response.Redirect call.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> Thanks for u r reply.
>> I tried this code but i got an error that
>> Server Error in '/maestro' Application.
>> HTTP Error 400 - Bad Request.
>> Version Information: ASP.NET Development Server 8.0.0.0
>> my code was
>>     Dim host As New
>> Uri("http://localhost/mapguide/mapagent/mapagent.fcgi")
>>         Dim conn As New HttpServerConnection(host, "Administrator",
>> "admin",
>> "en", True)
>>         'You have to change the string below to point at a valid
>> WebLayout
>>         Dim weblayout As WebLayout =
>> conn.GetWebLayout("Library://Filebased
>> data/Layout/layout.WebLayout")
>>         Dim mapdefinition As MapDefinition =
>> conn.GetMapDefinition(weblayout.Map.ResourceId)
>>         weblayout.Map.InitialView = New MapViewType()
>>         weblayout.Map.InitialView.Scale = 2000 'Zoom to 1:2000
>>         weblayout.Map.InitialView.CenterX = (mapdefinition.Extents.MaxX -
>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinX
>>         weblayout.Map.InitialView.CenterY = (mapdefinition.Extents.MaxY -
>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinY
>>         Dim tempid As ResourceIdentifier = New
>> ResourceIdentifier("layout",
>> OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, conn.SessionID)
>>         Response.Redirect("/mapguide/ajaxviewer/WEBLAYOUT=" &
>> Server.UrlEncode(tempid)
>> joscsu wrote:
>>>  Or this:
>>> System.Guid.NewGuid().ToString()
>>> ----- Ursprungligt meddelande ----
>>> Från: Maksim Sestic <max at geoinova.com>
>>> Till: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
>>> Skickat: tisdag 2 december 2008 16:49:21
>>> Ämne: RE: [mapguide-users] Runtime map problem
>>> Try this:
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
>>> godavarthi
>>> Sent: Tuesday, December 02, 2008 15:35
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: Re: [mapguide-users] Runtime map problem
>>> Hi,
>>> Thanku very much for ur help
>>> i tried this code
>>> but i got an error in the line
>>> Dim tempid as ResourceIdentifier = new
>>> ResourceIdentifier(Guid.NewGuid(),
>>> OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, con.SessionID)
>>> because of this Guid.NewGuid()
>>> 1) Actually what is this?
>>> 2) Which paramater we have to pass in this place instead of
>>> Guid.NewGuid()
>>> Regards,
>>> Padmini
>>>> I forgot to save the weblayout in the code below :(
>>>> Updated version is:
>>>> 'Setup connection
>>>> Dim host As New
>>>> Dim conn As New HttpServerConnection(host, "Administrator", "admin",
>>>> "en", True)
>>>> 'You have to change the string below to point at a valid WebLayout Dim
>>>> weblayout as WebLayout =
>>>> con.GetWebLayout("Library://mylayout.WebLayout")
>>>> Dim mapdefinition as MapDefinition =
>>>> con.GetMapDefinition(weblayout.Map.ResourceId)
>>>> 'Modify the initial view of the weblayout weblayout.Map.InitialView =
>>>> new MapViewType() weblayout.Map.InitialView.Scale = 2000 'Zoom to
>>>> 1:2000 weblayout.Map.InitialView.CenterX = (mapdefinition.Extents.MaxX
>>>> 'Obtain a unique session based id for the temporary weblayout (which
>>>> is a copy of an existing WebLayout) Dim tempid as ResourceIdentifier =
>>>> new ResourceIdentifier(Guid.NewGuid(),
>>>> 'Save the layout, otherwise you can't reference it
>>>> con.SaveResourceAs(weblayout, tempid)
>>>> 'Open the viewer, and use the temporary layout, since the map only
>>>> exists in the 'current session, we must use that session, and NOT
>>>> supply username/password
>>>> 'BEWARE: The session belongs to the Administrator account, so the user
>>>> gets full access to MapGuide (delete, modify, etc.)
>>>> Response.Redirect("/mapguide/ajaxviewer/?WEBLAYOUT=" &
>>>> Server.UrlEncode(tempid) & "&SESSION=" &
>>>> Server.UrlEncode(con.SessionID))
>>>>> 2. LayerDefinition, references a FeatureSource 3. MapDefinition,
>>>>> references multiple LayerDefinitions 4. WebLayout, references a
>>>>> MapDefinition
>>>>> All these items must be in a repository (either Library or Session),
>>>>> otherwise they can't be referenced.
>>>>> When you write that you want to "create a WebLayout programatically",
>>>>> do you want to create ALL the above items, or do you have layers and
>>>>> featuresources?
>>>>> (1) If you want to generate a WebLayout ResourceID, you should use:
>>>>> Dim res As New ResourceIdentifier("Filebased data/Maps/mapdata",
>>>>> ResourceTypes.WebLayout)
>>>>> If you want to read the name of an existing MapDefinition from
>>>>> another layout, you must do:
>>>>> Dim weblayout as WebLayout =
>>>>> Dim res as String = webLayout.Map.ResourceId
>>>>> (2) I don't understand the question.
>>>>> (3) The MapDefinition is an Xml document. Inside, it references
>>>>> layers, which references featuresources, as described above. It is
>>>>> very slow to do this, so when you open a map in the browser, the xml
>>>>> is transformed into a binary object. This object contains all the
>>>>> info from the MapDefinition and some info from the layers and
>>>>> featuresources.
>>>>> You need to know this, because if you try to toggle layer visibility
>>>>> in the MapDefinition, nothing happens. In short, the Runtime Map is a
>>>>> binary object that you can manipulate using the MapGuide (and
>>>>> Maestro)-API, and it only works for a displayed map.
>>>>> Upon startup, the Runtime Map is identical to the MapDefinition it
>>>>> was created from.
>>>>> A short example of using an existing WebLayout:
>>>>> Dim host As New
>>>>> "en", True)
>>>>> weblayout.Map.InitialView = new MapViewType()
>>>>> mapdefinition.Extents.MinX) + mapdefinition.Extents.MinY Dim tempid
>>>>> as ResourceIdentifier = new ResourceIdentifier(Guid.NewGuid(),
>>>>> Server.UrlEncode(tempid) & "&USERNAME=Anonymous&PASSWORD=")
>>>>>> Hi,
>>>>>> actually i wrote the code as
>>>>>>     Dim host As New
>>>>>> "admin", "en", True)
>>>>>> data/Maps/mapdata",
>>>>>> ResourceTypes.MapDefinition)
>>>>>>         Dim mapId As String = res.ResourceId
>>>>>> with that i got the map resource id.
>>>>>> But actually to run the application the url in the browser must be
>>>>>> like
>>>>>> http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fF
>>>>>> ilebased+data%2fLayout%2flayout.WebLayout
>>>>>> 1) How can i get this weblayout (like
>>>>>> Library%3a%2f%2fFilebased+data%2fLayout%2flayout.WebLayout)
>>>>>> programmetically
>>>>>> 2) I want to redirect to the ajax viewer sample application through
>>>>>> asp.net (like given by u )
>>>>>> Response.Redirect("/mapguide/ajaxviewer/?WEBLAYOUT=...resourceId
>>>>>> for
>>>>>> your WebLayout...&USERNAME=Anonymous&PASSWORD=");
>>>>>> 3) Can u plz tell me the purpose of runtime map (actualli iam in
>>>>>> configusing
>>>>>> state)
>>>>>>> Instead of re-posting the original question, could you try to
>>>>>>> explain what parts of my previous reply that are unclear or wrong?
>>>>>>> http://www.nabble.com/How-to-Load-Runtime-map-in-mapviewerajax-to20
>>>>>>> 704038.html#a20769349
>>>>>>>>   Hi ,
>>>>>>>> iam using mapguide open source 2.0( with .Net 2.0 + IIS 5.1) Iam
>>>>>>>> using dotnet viewer sample while running the application i
>>>>>>>> observed that the layout path given in the application.
>>>>>>>> as
>>>>>>>> String webLayout =
>>>>>>>> "Library://Samples/Sheboygan/Layouts/SheboyganAspTiled.WebLayout";
>>>>>>>>   it works but now i want to create this weblayout in run time (by
>>>>>>>> code)
>>>>>>>> using mapguide maestro api
>>>>>>>> for this purpose i followed the link
>>>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/Run
>>>>>>>> timeMap
>>>>>>>> but i didnt get any out.
>>>>>>>> can u plz tell me
>>>>>>>> 1) how to create this weblayout in run time
>>>>>>>> 2) How it will works
>>>>>>>> If u know this plz tell me the procedure.
>>>>>>>> Regards,
>>>>>>>> Padmini.
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> View this message in context:
>>> http://www.nabble.com/Runtime-map-problem-tp20789983p20793385.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> __________ Information from ESET NOD32 Antivirus, version of virus
>>> signature
>>> database 3658 (20081202) __________
>>> The message was checked by ESET NOD32 Antivirus.
>>> http://www.eset.com
>>>       __________________________________________________________
>>> Låna pengar utan säkerhet. Jämför vilkor online hos Kelkoo.
>>> http://www.kelkoo.se/c-100390123-lan-utan-sakerhet.html?partnerId=96915014
View this message in context: http://www.nabble.com/Runtime-map-problem-tp20789983p20810836.html
