[mapguide-users] Permanent changes in data
Zac Spitzer zac.spitzer at gmail.com
Wed Dec 3 18:46:07 EST 2008
I have added a simple test case to the bug which demonstrates the problem
and how to update your existing code to be safe
z
On Wed, Dec 3, 2008 at 12:16 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> I just bumped that bug to critical after some reflection as that is a
> serious potential dataloss bug IMHO
> On Tue, Dec 2, 2008 at 8:08 AM, Kenneth Skovhede, GEOGRAF A/S
> <ks at geograf.dk> wrote:
>> You could be affected by this bug:
>> http://trac.osgeo.org/mapguide/ticket/649
>> Otherwise, try to post a section of the code,
>> maybe someone will spot something obvious.
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> Stefan Dalakov skrev:
>>> Hi all,
>>> I am trying to add a feature (permanently) to a data source.
>>> I am using MGOS 1.2 and tried Sheboygan samples, where this part is not
>>> working, I have not explored the reason yet.
>>> My idea is to digitize a feature ( a line ) and add it permanently to an
>>> existing layer on the map.
>>> I wrote some code, and everything seems OK, no errors,  but at the end I
>>> have no feature added.
>>> Can someone help with a piece of code ?
>>> Thanks in advance
>>> Stefan Dalakov
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
