[mapguide-users] Jx Layout and Fusion
Paul Spencer pagameba at gmail.com
Thu Dec 4 21:44:52 EST 2008
Cool, you found it before I could even look at it!
On 4-Dec-08, at 3:02 PM, Mark Pendergraft wrote:
> I found the problem.
> In my index.html I had 2 references.  One to fusion.js and one to
> jx.js.
> When I removed the jx.js reference, everything worked just fine.
> Thanks
> a bunch for your help regardless.
> -Mark Pendergraft
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark
> Pendergraft
> Sent: Thursday, December 04, 2008 8:08 AM
> To: MapGuide Users Mail List
> Subject: RE: [mapguide-users] Jx Layout and Fusion
> Thanks Paul,
> Here is my index.html, applicaitondefintion.xml and css.
> The ApplicationDefinition.xml and CSS were copied from the
> fusion/templates/aqua/ directory from the MGOS 2.02 installation with
> only a few very slight modifications.
> I essentially want a layout that is all map, but I'd like the
> legend/SelectionPanel/TaskPane to be tabs (very similar to the
> LimeGold
> layout) but in a movable and resizable dialog.
> I did look through the examples on jxlib.org, but the jxlib seems to
> be
> a later iteration of the code.  I am able to create a tabbox in a
> dialog
> using the jxlib, just not using the fusion libraries.
> Thanks for your help.
> -Mark Pendergraft
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul
> Spencer
> Sent: Thursday, December 04, 2008 5:33 AM
> Subject: Re: [mapguide-users] Jx Layout and Fusion
> Hi Mark,
> this is probably something to do with Jx.  Jx.Layout is used to make
> things fill their containers, it sounds like you are missing
> something.
> Perhaps if you post your code+html+css we could advise you ...
> Cheers
> Paul
> On 3-Dec-08, at 1:46 PM, Mark Pendergraft wrote:
>> I have a question about the Jx libraries in relation to Fusion.  I'm
>> trying to build my own layout for fusion similar to the aqua layout
>> supplied with MGOS.  I would like the Legend, SelectionPanel, and
>> Task
>> Pane to show up as tabs in a dialog.  The code works and they are
>> displayed as such, but the tabbox doesn't take up the entire dialog,
>> so there are scroll bars up/down and left/right and there is blank
>> space on the bottom and right of the dialog that the tabbox sits in.
>> There is also blank space on the bottom of the dialog that I have
>> created for the overview map, even though I used the same exact code
>> as the provided template.  Is this a Jx issue, or are the sizes of
>> the
>> controls handled in another part of the code?
>> I looked in the css for the template, and I didn't see anything.
>> Also, If I create separate dialog boxes for all three elements
>> (taskpane, selectionpanel, and legend) than each element fills it's
>> dialog completely like it's supposed to.
>> Thanks for the help!
>> -Mark Pendergraft
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
