[mapguide-users] Runtime map
Zac Spitzer zac.spitzer at gmail.com
Fri Dec 5 05:11:19 EST 2008
what do you think a run time map is?
On Fri, Dec 5, 2008 at 8:45 PM, padmini godavarthi
<godavarthi.padmini at gmail.com> wrote:
> hi,
> thanks for ur reply.
> but i didnt get u.
> can u explain me briefly.
> Thanks and Regards,
> Padmini
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> If you are using the AJAX, DWF or Fusion viewer only,
>> you probably never want to create a runtime map.
>> The official viewers create the runtime map for you.
>> (and overwrite any you have created).
>> In that situation, you will need to load the current runtime map from
>> the repository,
>> modify it, save it, and refresh the client.
>> You would the pass the SessionID to your ASPX code, and
>> open the connection using:
>> conn = new HttpServerConnection(host, sessionId, "en", True)
>> Then you will load the runtime map (delete the create call):
>> Dim rtMap As RuntimeClasses.RuntimeMap = conn.GetRuntimeMap(rtMapId)
>> Modify it, eg:
>>  rtMap.Layers(0).Visible = False
>> and Save it:
>> conn.SaveRuntimeMap(rtMap);
>> Then in javascript do:
>> GetMapFrame().Refresh();
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> padmini godavarthi skrev:
>>> Hi,
>>> iam using mapguide opensource 2.0(.net 2.0 +IIS 5.1).
>>> i saw the runtime map sample application in the url
>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/RuntimeMap
>>> according to the sample application i changed my code as
>>>                Dim host As New
>>> Uri("http://localhost/mapguide/mapagent/mapagent.fcgi")
>>>         Dim conn As New HttpServerConnection(host, "Administrator",
>>> "admin",
>>> "en", True)
>>>         Dim res As New ResourceIdentifier("Filebased data/Maps/mapdata",
>>> ResourceTypes.MapDefinition)
>>>         Dim mapId As String = res.ResourceId
>>>         Dim mapDef As MapDefinition = conn.GetMapDefinition(mapId)
>>>         Dim mapName As String = res.Name
>>>         Dim rtMapId As String = New ResourceIdentifier(mapName,
>>> ResourceTypes.RuntimeMap, conn.SessionID)
>>>         conn.CreateRuntimeMap(rtMapId, mapDef)
>>> i didnt get this one
>>> 1) What i have to do with this?
>>> 2) What will be the output
>>> If anybody knows me can u plz tell me the procedure
>>> Regards,
>>> Padmini
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://www.nabble.com/Runtime-map-tp20830536p20850643.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
