[mapguide-users] Using Fusion functions from a separate iframe
Woodman, Jason JWoodman at emht.com
Fri Dec 5 08:55:46 EST 2008
Paul,
Thanks for the explanation on how frames work and how to get a reference
to them. I was trying to reference to functions in my map frame
directly; once I added to 'window.top' to my code I was able to get to
the map frame.
In my JavaScript file I created a reference to the iframe and from there
I was able to use Firefox/Firebug to figure out the objects/functions I
needed to access the map commands.
var map = window.top.frames.map;
var fusion = map.Fusion();
Thanks again for you help.
Jason
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul
Spencer
Sent: Thursday, December 04, 2008 9:44 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Using Fusion functions from a seperate
iframe
Each frame is a separate document, which means it has its own 'window'
global variable.  One of the members of window is parent which refers
to the parent window of the current window.  Normally this is a self-
reference but if you are using frames then it refers to the parent
frame or frameset.  In your case, code running in map iframe can use
window.parent to refer to the parent page.  There is another property,
top which refers to the ultimate parent directly in the case of nested
frames.  Window also has a frames member which can be used to
reference the individual frames within the window.  So ... from the
code iframe, you should be able to do something like this:
window.top.frames.map.someFunction();
which in this case is the same as:
window.parent.frames.map.someFunction();
Note that the same origin policy applies to frames, restricting access
to frames that are loaded from different domains.
Cheers
Paul
On 4-Dec-08, at 8:50 AM, Jason Woodman wrote:
> I'm trying to access the fusion commands for a map from a javascript
> function
> in a separate iframe.  Does anyone know how to do this and can
> supply some
> pointers or sample code on how to get a reference to the fusion
> commands in
> one iframe from another iframe.
> Here is my page setup
> | parent page                       |
> | | map iframe | code iframe | |
> My javascript function is in the code iframe, and I need to be able
> to have
> it access the map functions in the map iframe so I can do things
> like select
> objects, zoom to a selection, and the like.
> Thanks,
> Jason Woodman
> EMH&T, Inc.
http://www.nabble.com/Using-Fusion-functions-from-a-seperate-iframe-tp20
833758p20833758.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
CONFIDENTIALITY NOTICE: This e-mail message is
intended only for the person or entity to which it
is addressed and may contain confidential and/or
privileged material. Any unauthorized review, use,
disclosure or distribution is prohibited. If you are
not the intended recipient, please contact the sender
by reply e-mail and destroy all copies of the original
message. If you are the intended recipient but do not
wish to receive communications through this medium,
please so advise the sender immediately.
