[mapguide-users] Runtime map
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Dec 5 15:33:43 EST 2008
I don't know how to explain it better than I described in the mails or
in the developer guide:
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/basics
Creating a runtime map has advanced uses.
Most likely, you will load a runtime map created by a viewer.
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> i dont know about the runtime map.
> thats why iam waiting for someone to explain about the runtime map
> Regards,
> padmini
> zspitzer wrote:
>> what do you think a run time map is?
>> On Fri, Dec 5, 2008 at 8:45 PM, padmini godavarthi
>> <godavarthi.padmini at gmail.com> wrote:
>>> hi,
>>> thanks for ur reply.
>>> but i didnt get u.
>>> can u explain me briefly.
>>> Thanks and Regards,
>>> Padmini
>>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>>> If you are using the AJAX, DWF or Fusion viewer only,
>>>> you probably never want to create a runtime map.
>>>> The official viewers create the runtime map for you.
>>>> (and overwrite any you have created).
>>>> In that situation, you will need to load the current runtime map from
>>>> the repository,
>>>> modify it, save it, and refresh the client.
>>>> You would the pass the SessionID to your ASPX code, and
>>>> open the connection using:
>>>> conn = new HttpServerConnection(host, sessionId, "en", True)
>>>> Then you will load the runtime map (delete the create call):
>>>> Dim rtMap As RuntimeClasses.RuntimeMap = conn.GetRuntimeMap(rtMapId)
>>>> Modify it, eg:
>>>>  rtMap.Layers(0).Visible = False
>>>> and Save it:
>>>> conn.SaveRuntimeMap(rtMap);
>>>> Then in javascript do:
>>>> GetMapFrame().Refresh();
>>>>> Hi,
>>>>> iam using mapguide opensource 2.0(.net 2.0 +IIS 5.1).
>>>>> i saw the runtime map sample application in the url
>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/RuntimeMap
>>>>> according to the sample application i changed my code as
>>>>>                Dim host As New
>>>>> Uri("http://localhost/mapguide/mapagent/mapagent.fcgi")
>>>>>         Dim conn As New HttpServerConnection(host, "Administrator",
>>>>> "admin",
>>>>> "en", True)
>>>>>         Dim res As New ResourceIdentifier("Filebased
>>>>> data/Maps/mapdata",
>>>>> ResourceTypes.MapDefinition)
>>>>>         Dim mapId As String = res.ResourceId
>>>>>         Dim mapDef As MapDefinition = conn.GetMapDefinition(mapId)
>>>>>         Dim mapName As String = res.Name
>>>>>         Dim rtMapId As String = New ResourceIdentifier(mapName,
>>>>> ResourceTypes.RuntimeMap, conn.SessionID)
>>>>>         conn.CreateRuntimeMap(rtMapId, mapDef)
>>>>> i didnt get this one
>>>>> 1) What i have to do with this?
>>>>> 2) What will be the output
>>>>> If anybody knows me can u plz tell me the procedure
>>>>> Regards,
>>>>> Padmini
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> View this message in context:
>>> http://www.nabble.com/Runtime-map-tp20830536p20850643.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081205/ea825876/attachment.html
