[mapguide-users] Draw a point,polgon
padmini godavarthi
godavarthi.padmini at gmail.com
Mon Dec 8 12:09:38 EST 2008
Thanks
1) How tio use FDo
can u give me the sample code
Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> You will need to use the FDO or similar access.
> There exists javascript functions to digitize point/line/polygon.
> Once done, you can send the digitized data to the server, and insert it
> into a FeatureSource.
> The "Buffer" code in the AJAX viewer shows how to insert such a feature
> into a
> temporary SDF FeatureSource. You can do the same with an existing database
> or SDF FeatureSource.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> Thanks for u r reply.
>> 1) I have an button for draw point and polygon
>> when i clicked on the map some place a new point and polygon has to be
>> drawn.
>> How is it possible?
>> Thanks and Regards,
>> Padmini
>>> How do you define new?
>>> If you add it to the database, it will automatically be visible when the
>>> map refreshes.
>>>> Hi iam using mapguide opensource 2.0(with .net 2.0 +IIS 5.1)
>>>> My question is that
>>>> 1) How to draw a new point,polygon on the map(either from database or
>>>> normal) as a new layer
>>>> If u knows plz help me
>>>> Thanks and Regards,
>>>> Padmini
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Draw-a-point%2Cpolgon-tp20868670p20899349.html
