[mapguide-users] New King.Oracle 0.8 - improved performance
born2bwild edelaite at mairie-metz.fr
Tue Dec 9 03:48:25 EST 2008
I test with a new instance with only 1 table like :
 Nom                                       NULL ?   Type
 GID                                                     NUMBER(10)
 GEOMETRY                                           MDSYS.SDO_GEOMETRY
 APIC_STYLE                                         VARCHAR2(2000)
 DESIGNA                                              VARCHAR2(400)
 IDENT                                                 VARCHAR2(400)
 APIC_SPACE                                         NUMBER(10)
 APIC_STATE                                         NUMBER(10)
 APIC_CDATE                                         DATE
 APIC_MDATE                                         DATE
In "http://...../schemareport/describeschema.php"
With the owner in feature source, i got :
"Failed to retrieve message for "MgIndexOutOfRangeException". The value is
invalid because it is too large. "
width another user  in feature source, i got :
"An exception occurred in FDO component. ORA-00933:SQL command not properly
ended"
And in Maestro, when i want to create a new layer, i got (either with owner
or other user) :
"Failed to read schema from data source. Thet operation gave the error
massage : (559) MgFdoException : An Excetion occured in FDO component.
ORA-00933:SQL command not properly ended
Exception occured in method MgServerDescribeSchema.ExecuteDescribeSchema at
line 176 in file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerDescribeSchema.cpp"
Haris Kurtagic wrote:
> One way would be to install new XE instance, copy tables (e.g. 1 row)
> one by one and try to isolate table which is causing problems.
> Then you could use desc or some other way , depending on tools you are
> using, to send me SQL which creates that table.
> Haris
View this message in context: http://n2.nabble.com/New-King.Oracle-0.8---improved-performance-tp1519120p1633055.html
