[mapguide-users] How to highlight an area on a map?
jamesdudden
jamesdudden at blueyonder.co.uk
Tue Dec 9 06:45:47 EST 2008
This i am finiding is a bit more complex than it sounds and i really don't
know where to start so any help or advice would be appreciated.
I need to create a complex query and highlight the results as a new layer.
My map has a layer of fields, a layer of aonb's (areas of natural beauty)
and a layer of power sources. These all layer on top of each other so some
fields will be in the aonb's, some outside and some half in, half out etc.
Query - I need to find all fields that are not within an aonb - including
fields that are half in, half out - and are 100 meters from a power source.
1st problem - I can create a query (taken from dotnetsamples) to find all
the fields outside an aonb but not ones that cross the aonb.
2nd problem - I can create a buffer around my powersource but i don't know
how to combine this with my query.
3rd problem - I would like the query to return the results as a new
digitised layer that only creates the part of the field that is outside of
the aonb.
Is any of this possible? - please any help would be gladly received
Regards
James
Straightforward solutions to take care of your business
http://www.software-matters.co.uk Software Matters
View this message in context: http://www.nabble.com/How-to-highlight-an-area-on-a-map--tp20913178p20913178.html
