[mapguide-users] Execute a script with mapgudie studio 2.0
ziburudebian at free.fr
Fri Dec 12 05:03:56 EST 2008
I means that in my layout file in mapguide studio, i parameter the new command
(tools and menus) : i create a new custom command : 'Execute a script'. In the
aera 'Adding Parameters' Mapguide studio Help indicate that you must edit the
name of your script : so i take myfile.aspx.
But when i run, nothing occurs !
Thanks
Selon Ivan Milicevic <Ivan.Milicevic at supranet.hr>:
> What do you mean by "edit the nameo f my aspx file"? Could you be more
> specific?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of euskalmap
> Sent: Friday, December 12, 2008 10:32 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Execute a script with mapgudie studio 2.0
> hi,
> when i try to execute a script with a custom command in mapguide studio
> nothing occurs;
> if i edit an instrction like alert("hello") , it is run but if a edit
> the
> name of my aspx file myfiles.aspx, for example) , nothing occurs
> have you an idea?
> thanks
> euskalmap
> config.
> mapguide ose 2.2
> windows 2003 server sp2
> http://www.nabble.com/Execute-a-script-with-mapgudie-studio-2.0-tp209715
> 93p20971593.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
