[mapguide-users] Execute a script with mapgudie studio 2.0
Ivan Milicevic Ivan.Milicevic at supranet.hr
Fri Dec 12 08:28:23 EST 2008
Here http://www.pageresource.com/jscript/jwinopen.htm you can find fine
reference for  opening new window. If you need to pass some oft he
mapguide variables to the opened file as session id, map name, number of
selected object's see the viewer API.
Please don't hesitate to write us if you have any further questions.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of euskalmap
Sent: Friday, December 12, 2008 2:17 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Execute a script with mapgudie studio 2.0
Ok, thanks very match, i have understand
regards
Kenneth Skovhede, GEOGRAF A/S wrote:
> The "Command Name" is not the name of a file, it's a logical name of
the
> command, used to identify it in Studio.
> In the "Additional Parameters" area, you enter a javascript.
> If you enter the name of a file, it won't load, because a filename is
> not a javascript.
> If your script is in an aspx page, you can try the "invoke url" option
> instead.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> ziburudebian at free.fr skrev:
>> I means that in my layout file in mapguide studio, i parameter the
new
>> command
>> (tools and menus) : i create a new custom command : 'Execute a
script'.
>> In the
>> aera 'Adding Parameters' Mapguide studio Help indicate that you must
edit
>> the
>> name of your script : so i take myfile.aspx.
>> But when i run, nothing occurs !
>> Thanks
>> Selon Ivan Milicevic <Ivan.Milicevic at supranet.hr>:
>>> What do you mean by "edit the nameo f my aspx file"? Could you be
more
>>> specific?
>>> From: mapguide-users-bounces at lists.osgeo.org
euskalmap
>>> Sent: Friday, December 12, 2008 10:32 AM
>>> Subject: [mapguide-users] Execute a script with mapgudie studio 2.0
>>> hi,
>>> when i try to execute a script with a custom command in mapguide
studio
>>> nothing occurs;
>>> if i edit an instrction like alert("hello") , it is run but if a
edit
>>> the
>>> name of my aspx file myfiles.aspx, for example) , nothing occurs
>>> have you an idea?
>>> thanks
>>> euskalmap
>>> config.
>>> mapguide ose 2.2
>>> windows 2003 server sp2
>>> View this message in context:
http://www.nabble.com/Execute-a-script-with-mapgudie-studio-2.0-tp209715
>>> 93p20971593.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
euskalmap,
My configuration
Mapguide OSE 2.2
Autodesk Mapguide Studio 2009
Windows XP PRO SP2
I.I.S 6.0
93p20975455.html
