[mapguide-users] mapguide-users Digest, Vol 24, Issue 11
JonnieGIS at PAT
jmatpat at yahoo.ca
Fri Dec 12 19:37:05 EST 2008
1. Try setting the IIS_WPG permissions on windows temp folders and php folder
2. Make sure the php directory is at the start of the path.
3. Check the php.ini and follow the directions snipped from Crispin below...
4. Restart server.
RE: MGOS2.0.2 bundled installation won'tsupportphp on IIS6 by Crispin @
1Spatial Sep 29, 2008; 12:10pm :: Rate this Message: - Use ratings to
moderate (?)
Reply | Reply to Author | Print | View Threaded | Show Only this Message
Folks,
File should be attached and here are our 1Spatial internal notes for getting
the PHP login page to work:
Crispin
*) Edit the PHP.ini file in "C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\Php"
Find the section for "Windows Extensions" and add in the two extension
entries as per below. There will also be a "php_MapGuideApi.dll" at the
bottom of the list, comment that one out with a ";"
I once tried putting the php_MapGuideApiEnvConfig.dll entry at the bottom of
the list and something didn't work so I recommend putting both entries at
the top of the extensions.
*) Restart IIS
;Windows Extensions
;Note that ODBC support is built in, so no dll is needed for it.
extension=php_MapGuideApiEnvConfig.dll
extension=php_MapGuideApi.dll
syncro balon wrote:
> hello,
> I ve intalled MapGuide Open Source 2.0 (with DotNet & IIS)bat i can't
> connect to "MapGuide Site Administrator" even if i have entred login
> "administrator" password "admin"
> ==> "Error 500"
> please help me > From: mapguide-users-request at lists.osgeo.org> Subject:
> mapguide-users Digest, Vol 24, Issue 11> To:
> mapguide-users at lists.osgeo.org> Date: Thu, 11 Dec 2008 12:00:09 -0500> >
> Send mapguide-users mailing list submissions to>
> mapguide-users at lists.osgeo.org> > To subscribe or unsubscribe via the
> World Wide Web, visit>
> http://lists.osgeo.org/mailman/listinfo/mapguide-users> or, via email,
> send a message with subject or body 'help' to>
> mapguide-users-request at lists.osgeo.org> > You can reach the person
> managing the list at> mapguide-users-owner at lists.osgeo.org> > When
> replying, please edit your Subject line so it is more specific> than "Re:
> Contents of mapguide-users digest..."> > > Today's Topics:> > 1. RE:
> Installation mapguide 64bits (Andy Morsell)> 2. Help with Mapguide
> Proposal (Gabriel.Ramirez)> 3. RE: Help with Mapguide Proposal (Andy
> Morsell)> 4. Wanna Share For Beginner (ajid1980)> 5. Polygon Layer
> (padmini godavarthi)> 6. FW: [fdo-users] Any MySQL users out there? (Orest
> Halustchak)> 7. Re: FW: [fdo-users] Any MySQL users out there? (Zac
> Spitzer)> 8. Re: Wanna Share For Beginner (ajid1980)> 9. Error in
> compiling mapguide server on debian 4.0 64 bits> (luca1982)> > >
> Message: 1> Date: Wed, 10 Dec 2008 09:30:16 -0800> From: "Andy Morsell"
> <amorsell at spatialgis.com>> Subject: RE: [mapguide-users] Installation
> mapguide 64bits> To: "'MapGuide Users Mail List'"
> <mapguide-users at lists.osgeo.org>> Message-ID:
> <016401c95aec$f7f39fd0$e7dadf70$@com>> Content-Type: text/plain;
> charset="us-ascii"> > It will work at as a 32 bit app using WOW64. You
> will have to configure IIS> to run 32-bit applications, however.> >
> http://www.microsoft.com/technet/prodtechnol/WindowsServer2003/Library/IIS/1>
> 3f991a5-45eb-496c-8618-2179c3753bb0.mspx?mfr=true > > Andy Morsell, P.E.>
> Spatial Integrators, Inc.> www.SpatialGIS.com> > > -----Original
> Message-----> From: mapguide-users-bounces at lists.osgeo.org>
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of EdH> Sent:
> Wednesday, December 10, 2008 2:29 AM> To: mapguide-users at lists.osgeo.org>
> Subject: Re: [mapguide-users] Installation mapguide 64bits> > > > I've
> read conflicting opinions about MGOS and 64 bit. Has anyone got any>
> pointers on installing MGOS 2.0.x on a Windows 2003 64-bit server with
> IIS> and PHP? > > -- > View this message in context:>
> http://n2.nabble.com/Installation-mapguide-64bits-tp1365405p1638140.html>
> Sent from the MapGuide Users mailing list archive at Nabble.com.> >
> _______________________________________________> mapguide-users mailing
> list> mapguide-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/mapguide-users> > > >
> ------------------------------> > Message: 2> Date: Wed, 10 Dec 2008
> 13:10:15 -0800 (PST)> From: "Gabriel.Ramirez"
> <gabriel.ramirez at ventura.org>> Subject: [mapguide-users] Help with
> Mapguide Proposal> To: mapguide-users at lists.osgeo.org> Message-ID:
> <20944227.post at talk.nabble.com>> Content-Type: text/plain;
> charset=us-ascii> > > I need some help putting a proposal together to show
> out IT committee that> "Map Guide" is a secure program to use within our
> intranet and internet. We> might have some push back from one department
> that is using ArcIMS and I> will need to show the pros and cons against
> ArcIMS. (I work for local County> Government, we have over 1,500 in our
> agency). > > Any leads or tips would be welcomed.> > > -- > View this
> message in context:
> http://www.nabble.com/Help-with-Mapguide-Proposal-tp20944227p20944227.html>
> Sent from the MapGuide Users mailing list archive at Nabble.com.> > > >
> ------------------------------> > Message: 3> Date: Wed, 10 Dec 2008
> 17:30:47 -0800> From: "Andy Morsell" <amorsell at spatialgis.com>> Subject:
> RE: [mapguide-users] Help with Mapguide Proposal> To: "'MapGuide Users
> Mail List'" <mapguide-users at lists.osgeo.org>> Message-ID:
> <01cd01c95b30$18768c70$4963a550$@com>> Content-Type: text/plain;
> charset="us-ascii"> > There are a couple of white papers on the Autodesk
> MapGuide Enterprise web> site that you would be interested in. Although
> written for MapGuide> Enterprise, all of the articles apply to MapGuide
> Open Source. They can be> found at:>
> http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7798553> > One
> discusses migrating ArcIMS to MapGuide and one discusses security. I'm>
> not sure what your IT folks want in terms of a "secure" web-based
> program,> but I imagine that either product could meet that requirement if
> the web> side of things were configured properly. Here are some other
> thoughts on> this topic. Some of the ArcGIS Server information is feedback
> from some> clients:> > - Software cost: MapGuide Open Source costs
> nothing. ArcGIS Server is> expensive.> - MapGuide Open Source is open
> source, ArcGIS Server is not.> - MapGuide Open Source tends to require
> more tweaking than ArcGIS Server to> obtain reasonable performance. > -
> ArcGIS Server raster performance is far better than MapGuide Open Source.>
> And, raster in SDE including on-the-fly coordinate transformation is>
> supported.> - ArcGIS Server provides some level of integration between
> desktop, server> and mobile clients.> - The authoring packages for
> MapGuide Open Source, such as Autodesk MapGuide> Studio or MapGuide
> Maestro (open source) are superior to anything that ESRI> has.> > I'm sure
> there are some folks on this list that have used both MapGuide Open>
> Source / Enterprise and ArcGIS Server (or ArcIMS) and it would be>
> interesting to hear their stories.> > Andy Morsell, P.E.> Spatial
> Integrators, Inc.> www.SpatialGIS.com> > > -----Original Message----->
> Gabriel.Ramirez> Sent: Wednesday, December 10, 2008 1:10 PM> To:
> mapguide-users at lists.osgeo.org> Subject: SPAM-LOW: [mapguide-users] Help
> with Mapguide Proposal> > > I need some help putting a proposal together
> to show out IT committee that> "Map Guide" is a secure program to use
> within our intranet and internet. We> might have some push back from one
> department that is using ArcIMS and I> will need to show the pros and cons
> against ArcIMS. (I work for local County> Government, we have over 1,500
> in our agency). > > Any leads or tips would be welcomed.> > > -- > View
> ------------------------------> > Message: 4> Date: Thu, 11 Dec 2008
> 01:53:31 -0800 (PST)> From: ajid1980 <ah_jid at yahoo.com>> Subject:
> [mapguide-users] Wanna Share For Beginner> To:
> <20952483.post at talk.nabble.com>> Content-Type: text/plain;
> charset=us-ascii> > > Hello > Just Wanna Share For Beginner> > To view /
> download the file, simply click on the link below > >
> http://www.ziddu.com/download/2897823/GoogleEarth.zip.html> >
> http://www.ziddu.com/download/2897797/Samples.zip.html> >
> http://www.ziddu.com/download/2897498/MGP.zip.html> >
> http://www.ziddu.com/download/2896957/ConfiguringAWMSFeatureSource.pdf.html>
> http://www.ziddu.com/download/2896601/InstallConfigureMgOpenSourceOnWindows.pdf.html>
> http://www.ziddu.com/download/2896587/BuildConfigureMgOpenSourceOnWindows.pdf.html>
> > http://www.ziddu.com/download/2897055/SharpMap.zip.html> > > -- > View
> http://www.nabble.com/Wanna-Share-For-Beginner-tp20952483p20952483.html>
> ------------------------------> > Message: 5> Date: Thu, 11 Dec 2008
> 02:18:07 -0800 (PST)> From: padmini godavarthi
> <godavarthi.padmini at gmail.com>> Subject: [mapguide-users] Polygon Layer>
> <20952795.post at talk.nabble.com>> Content-Type: text/plain;
> charset=us-ascii> > > > > Hi,> iam using mapguide opensource 2.0 (with
> .net 2.0 +IIS 5.1)> > Now my doubt is that> > i had a weblayout with 2
> layers (polygon layer and one line layer) loaded> from the oracle
> database> > 1) How to select a polygon in the map programmitically > > can
> u send me the code (in .net ) for a hint> > Thanks and Regards,> Padmini>
> http://www.nabble.com/Polygon-Layer-tp20952795p20952795.html> Sent from
> ------------------------------> > Message: 6> Date: Thu, 11 Dec 2008
> 05:23:47 -0800> From: Orest Halustchak <orest.halustchak at autodesk.com>>
> Subject: [mapguide-users] FW: [fdo-users] Any MySQL users out there?> To:
> "mapguide-users at lists.osgeo.org" <mapguide-users at lists.osgeo.org>>
> Message-ID:>
> <F1AFC33B5AA87C4B85146A00AAF677DE38345F0063 at ADSK-NAMSG-02.MGDADSK.autodesk.com>>
> > Content-Type: text/plain; charset="us-ascii"> > Hi,> > Let us know if
> you use the FDO MySQL provider and which version of MySQL that you're
> using.> > See below ...> > > Thanks,> Orest.> > From:
> fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch> Sent:
> Wednesday, December 10, 2008 5:55 PM> To: FDO Users Mail List> Subject:
> RE: [fdo-users] Any MySQL users out there?> > MySQL is an interesting
> provider. I think MySQL is the immediate choice for most non-geo-savvy
> open source users-and as such it is important to support it-but it
> wouldn't be considered by geo-types because of its lack of support for
> non-BBOX comparison operations. I'd be interested to see the answer to
> this question; perhaps it would be good to ask on mapguide-users too?> >
> Maybe we should build a phone-home feature into FDO so we can count actual
> usage of the providers... just kidding :)> > Jason> > From: Orest
> Halustchak> Subject: [fdo-users] Any MySQL users out there?> > If you use
> MySQL and the FDO provider for MySQL, what version of MySQL are you
> using?> > The MySQL 5.1 GA version was released recently. Is anyone
> planning to move to 5.1 in the short term? It looks like the client
> libraries are not binary compatible with 5.0.> -------------- next part
> --------------> An HTML attachment was scrubbed...> URL:
> http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081211/0bd30276/attachment-0001.html>
> > ------------------------------> > Message: 7> Date: Fri, 12 Dec 2008
> 00:40:11 +1100> From: "Zac Spitzer" <zac.spitzer at gmail.com>> Subject: Re:
> [mapguide-users] FW: [fdo-users] Any MySQL users out> there?> To:
> "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>> Message-ID:>
> <7a85053e0812110540g728b5cc8r1589ba81cef505e2 at mail.gmail.com>>
> Content-Type: text/plain; charset=WINDOWS-1252> > I'm using it for one
> project> > mysql Ver 14.12 Distrib 5.0.51a, for redhat-linux-gnu (i686)
> using readline 5.0> > using mapguide 2.0.1> > z> > On Fri, Dec 12, 2008 at
> 12:23 AM, Orest Halustchak> <orest.halustchak at autodesk.com> wrote:> > Hi,>
> >> >> >> > Let us know if you use the FDO MySQL provider and which version
> of MySQL> > that you're using.> >> >> >> > See below …> >> >> >> >> >> >
> Thanks,> >> > Orest.> >> >> >> > From: fdo-users-bounces at lists.osgeo.org>
> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch> >
> Sent: Wednesday, December 10, 2008 5:55 PM> > To: FDO Users Mail List> >
> Subject: RE: [fdo-users] Any MySQL users out there?> >> >> >> > MySQL is
> an interesting provider. I think MySQL is the immediate choice for> > most
> non-geo-savvy open source users—and as such it is important to support> >
> it—but it wouldn't be considered by geo-types because of its lack of
> support> > for non-BBOX comparison operations. I'd be interested to see
> the answer to> > this question; perhaps it would be good to ask on
> mapguide-users too?> >> >> >> > Maybe we should build a phone-home feature
> into FDO so we can count actual> > usage of the providers… just kidding J>
> >> >> >> > Jason> >> >> >> > From: Orest Halustchak> > Subject:
> [fdo-users] Any MySQL users out there?> >> >> >> > If you use MySQL and
> the FDO provider for MySQL, what version of MySQL are> > you using?> >> >>
> >> > The MySQL 5.1 GA version was released recently. Is anyone planning to
> move> > to 5.1 in the short term? It looks like the client libraries are
> not binary> > compatible with 5.0.> >> >
> _______________________________________________> > mapguide-users mailing
> list> > mapguide-users at lists.osgeo.org> >
> http://lists.osgeo.org/mailman/listinfo/mapguide-users> >> >> > > > -- >
> Zac Spitzer -> http://zacster.blogspot.com> +61 405 847 168> > >
> ------------------------------> > Message: 8> Date: Thu, 11 Dec 2008
> 06:31:44 -0800 (PST)> From: ajid1980 <ah_jid at yahoo.com>> Subject: Re:
> <20956511.post at talk.nabble.com>> Content-Type: text/plain;
> http://www.ziddu.com/download/2897498/MGP.zip.html> > That Link Have Many
> Source Code Maestro.. May be it can help u to solve> problem..> -- > View
> http://www.nabble.com/Wanna-Share-For-Beginner-tp20952483p20956511.html>
> ------------------------------> > Message: 9> Date: Thu, 11 Dec 2008
> 08:09:25 -0800 (PST)> From: luca1982 <zanca82 at libero.it>> Subject:
> [mapguide-users] Error in compiling mapguide server on debian> 4.0 64
> bits> To: mapguide-users at lists.osgeo.org> Message-ID:
> <20958517.post at talk.nabble.com>> Content-Type: text/plain;
> charset=us-ascii> > > Hi everybody,> I'm trying to upgrade to mapguide 2.0
> on a 64 bits PC running debian 4.0.> I've install correctly FDO 3.3.0.>
> When running the "./build_oem.sh>
> --prefix=/usr/local/mapguideopensource-v2.0" script I got an error
> telling> "missing ./libtool" in the /Oem/gd/jpeg directory. I solved this
> error by> linking to /usr/bin/libtool, then it compiled all correctly.
> Then I run the> commands:> aclocal> libtoolize --force> automake
> --add-missing --copy> autoconf> ./configure
> --prefix=/usr/local/mapguideopensource-v2.0> > When finally building
> mapguide, I get the following error:> > > make[3]: Entering directory>
> `/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Core'>
> /bin/sh ../../../libtool --tag=CXX --mode=link g++ -g -D_DEBUG>
> -DACE_HAS_SVC_DLL=1 -g -D_DEBUG -o mgserver -version-info 7:0:0>
> -R/usr/local/fdo-3.3.0/lib>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/ACE/ACE_wrappers/ace>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/DWFTK7.1/develop/global/src/dwfcore>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/DWFTK7.1/develop/global/src/dwf>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/DWFTK7.1/develop/global/src/dwfemap>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/dbxml-2.3.10/install/lib>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/CoordinateSystem/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/MdfModel/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/MdfParser/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/Stylization/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/Renderers/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/Foundation/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/Geometry/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/PlatformBase/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/MapGuideCommon/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Common/Base/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Common/Cache/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Common/Manager/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Common/Thread/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Drawing/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Feature/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Kml/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Mapping/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Rendering/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Resource/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/ServerAdmin/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Site/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Tile/.libs>
> -R/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/UnitTesting/.libs>
> -L/usr/local/fdo-3.3.0/lib -L../../../Oem/ACE/ACE_wrappers/ace>
> -L../../../Oem/DWFTK7.1/develop/global/src/dwfcore>
> -L../../../Oem/DWFTK7.1/develop/global/src/dwf>
> -L../../../Oem/DWFTK7.1/develop/global/src/dwfemap>
> -L../../../Oem/dbxml-2.3.10/install/lib
> -L../../../Common/CoordinateSystem> -L../../../Common/MdfModel
> -L../../../Common/MdfParser> -L../../../Common/Stylization
> -L../../../Common/Renderers> -L../../../Common/Foundation
> -L../../../Common/Geometry> -L../../../Common/PlatformBase
> -L../../../Common/MapGuideCommon> -L../Common/Base -L../Common/Cache
> -L../Common/Manager -L../Common/Thread> -L../Services/Drawing
> -L../Services/Feature -L../Services/Kml> -L../Services/Mapping
> -L../Services/Rendering -L../Services/Resource> -L../Services/ServerAdmin
> -L../Services/Site -L../Services/Tile> ServerCoreBuild.o -lACE -ldb_cxx
> -ldbxml -ldwfcore -ldwftk -ldwfemap -lexpat> -lFDO-3.3.0
> -lExpressionEngine -lxalanMsg -lxalan-c -lxerces-c -lxqilla>
> -lMgFoundation -lMgGeometry -lMgPlatformBase -lMgMapGuideCommon>
> -lMgServerAdminService -lMgServerBase -lMgServerCache>
> -lMgServerDrawingService -lMgServerFeatureService -lMgServerKmlService>
> -lMgServerManager -lMgServerMappingService -lMgServerRenderingService>
> -lMgServerResourceService -lMgServerSiteService -lMgServerThread>
> -lMgServerTileService -lMgMdfModel -lMgMdfParser -lMgStylization>
> -lMgRenderers ../../../Common/Security/libMgSecurity.a> libtool: link:
> warning: `-version-info' is ignored for programs> g++ -g -D_DEBUG
> -DACE_HAS_SVC_DLL=1 -g -D_DEBUG -o .libs/mgserver> ServerCoreBuild.o
> -L/usr/local/fdo-3.3.0/lib>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/ACE/ACE_wrappers/ace>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/DWFTK7.1/develop/global/src/dwfcore>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/DWFTK7.1/develop/global/src/dwf>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/DWFTK7.1/develop/global/src/dwfemap>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/dbxml-2.3.10/install/lib>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/CoordinateSystem>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/MdfModel>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/MdfParser>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/Stylization>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/Renderers>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/Foundation>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/Geometry>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/PlatformBase>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/MapGuideCommon>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Common/Base>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Common/Cache>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Common/Manager>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Common/Thread>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Drawing>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Feature>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Kml>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Mapping>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Rendering>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Resource>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/ServerAdmin>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Site>
> -L/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Tile>
> -lACE -ldb_cxx -ldbxml>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/DWFTK7.1/develop/global/src/dwfcore/.libs/libdwfcore>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/DWFTK7.1/develop/global/src/dwf/.libs/libdwftk>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/DWFTK7.1/develop/global/src/dwfemap/.libs/libdwfemap>
> /usr/lib/libexpat.so -lFDO-3.3.0>
> /usr/local/fdo-3.3.0/lib/libExpressionEngine.so -lxalanMsg -lxalan-c>
> -lxerces-c>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/dbxml-2.3.10/install/lib/libxqilla.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/Foundation/.libs/libMgFoundation.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/Geometry/.libs/libMgGeometry.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/PlatformBase/.libs/libMgPlatformBase.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/MapGuideCommon/.libs/libMgMapGuideCommon.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/ServerAdmin/.libs/libMgServerAdminService.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Common/Base/.libs/libMgServerBase.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Common/Cache/.libs/libMgServerCache.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Drawing/.libs/libMgServerDrawingService.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Feature/.libs/libMgServerFeatureService.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Kml/.libs/libMgServerKmlService.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Common/Manager/.libs/libMgServerManager.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Mapping/.libs/libMgServerMappingService.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Rendering/.libs/libMgServerRenderingService.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Resource/.libs/libMgServerResourceService.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Site/.libs/libMgServerSiteService.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Common/Thread/.libs/libMgServerThread.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Tile/.libs/libMgServerTileService.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/MdfModel/.libs/libMgMdfModel.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/MdfParser/.libs/libMgMdfParser.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/Stylization/.libs/libMgStylization.so>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/Renderers/.libs/libMgRenderers.so>
> ../../../Common/Security/libMgSecurity.a -Wl,--rpath>
> -Wl,/usr/local/mapguideopensource/lib -Wl,--rpath>
> -Wl,/usr/local/fdo-3.3.0/lib -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/dbxml-2.3.10/install/lib>
> -Wl,--rpath -Wl,/usr/local/mapguideopensource-v2.0/lib -Wl,--rpath>
> -Wl,/usr/local/mapguideopensource-v2.0/server/lib -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/ACE/ACE_wrappers/ace>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/DWFTK7.1/develop/global/src/dwfcore>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/DWFTK7.1/develop/global/src/dwf>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/DWFTK7.1/develop/global/src/dwfemap>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/CoordinateSystem/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/MdfModel/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/MdfParser/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/Stylization/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/Renderers/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/Foundation/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/Geometry/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/PlatformBase/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Common/MapGuideCommon/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Common/Base/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Common/Cache/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Common/Manager/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Common/Thread/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Drawing/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Feature/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Kml/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Mapping/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Rendering/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Resource/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/ServerAdmin/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Site/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Tile/.libs>
> -Wl,--rpath>
> -Wl,/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/UnitTesting/.libs>
> /usr/bin/ld: warning: libxerces-c.so.27, needed by>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Oem/dbxml-2.3.10/install/lib/libxqilla.so,>
> may conflict with libxerces-c.so.25>
> /root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src/Services/Feature/.libs/libMgServerFeatureService.so:>
> undefined reference to>
> `IGWSFeatureQueryDefinition::Create(FdoIdentifierCollection*,>
> GWSQualifiedName const&, FdoFilter*)'> collect2: ld returned 1 exit
> status> make[3]: *** [mgserver] Error 1> make[3]: Leaving directory>
> make[2]: *** [all-recursive] Error 1> make[2]: Leaving directory>
> `/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server/src'> make[1]:
> *** [all-recursive] Error 1> make[1]: Leaving directory>
> `/root/mapguide_v2/fin-mapguide-2.0.2/mapguide-2.0.2/Server'> make: ***
> [all-recursive] Error 1> > Anyone can help?> > Some information on my
> system, if you need more information please let me> know, I'm not an
> expert of this kind of problems. Thanks!> > localhost:~# gcc -v> Using
> built-in specs.> Target: i486-linux-gnu> Configured with: ../src/configure
> -v> --enable-languages=c,c++,fortran,objc,obj-c++,treelang --prefix=/usr>
> --enable-shared --with-system-zlib --libexecdir=/usr/lib>
> --without-included-gettext --enable-threads=posix --enable-nls>
> --program-suffix=-4.1 --enable-__cxa_atexit --enable-clocale=gnu>
> --enable-libstdcxx-debug --enable-mpfr --with-tune=i686>
> --enable-checking=release i486-linux-gnu> Thread model: posix> gcc version
> 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)> localhost:~# > >
> localhost:~# libtool --version> ltmain.sh (GNU libtool) 1.5.22 Debian
> 1.5.22-4 (1.1220.2.365 2005/12/18> 22:14:06)> > > > localhost:~# cat
> /proc/cpuinfo> processor : 0> vendor_id : GenuineIntel> cpu family : 15>
> model : 6> model name : Intel(R) Xeon(TM) CPU 3.33GHz> stepping : 8> cpu
> MHz : 3333.362> cache size : 16384 KB> physical id : 0> siblings : 1> core
> id : 0> cpu cores : 1> fpu : yes> fpu_exception : yes> cpuid level : 6> wp
> : yes> flags : fpu tsc msr pae mce cx8 apic mca cmov pat pse36 clflush>
> dts acpi mmx fxsr sse sse2 ss ht tm syscall lm constant_tsc pni monitor>
> ds_cpl vmx est tm2 cid cx16 xtpr lahf_lm> bogomips : 8340.84> clflush size
> : 64> cache_alignment : 128> address sizes : 40 bits physical, 48 bits
> virtual> power management:> > processor : 1> vendor_id : GenuineIntel> cpu
> family : 15> model : 6> model name : Intel(R) Xeon(TM) CPU 3.33GHz>
> stepping : 8> cpu MHz : 3333.362> cache size : 16384 KB> physical id : 1>
> siblings : 1> core id : 0> cpu cores : 1> fpu : yes> fpu_exception : yes>
> cpuid level : 6> wp : yes> flags : fpu tsc msr pae mce cx8 apic mca cmov
> pat pse36 clflush> dts acpi mmx fxsr sse sse2 ss ht tm syscall lm
> constant_tsc pni monitor> ds_cpl vmx est tm2 cid cx16 xtpr lahf_lm>
> bogomips : 8340.84> clflush size : 64> cache_alignment : 128> address
> sizes : 40 bits physical, 48 bits virtual> power management:> >
> localhost:~# > -- > View this message in context:
> http://www.nabble.com/Error-in-compiling-mapguide-server-on-debian-4.0-64-bits-tp20958517p20958517.html>
> http://lists.osgeo.org/mailman/listinfo/mapguide-users> > > End of
> _________________________________________________________________
> Sur Windows Live Ideas, découvrez en exclusivité de nouveaux services en
> ligne... si nouveaux qu'ils ne sont pas encore sortis officiellement sur
> le marché !
> http://ideas.live.com
View this message in context: http://n2.nabble.com/RE%3A-mapguide-users-Digest%2C-Vol-24%2C-Issue-11-tp1648652p1650340.html
