[mapguide-users] [ZS2] Datasource Connection *.sdf (Add, Delete, Update and Edit)
anakando anakando at yahoo.com
Mon Dec 15 22:41:37 EST 2008
ajid you are in malaysia right?so am i,currently at sri kembangan. i have
looked at your sample.it seems that you wanna create a point based on the
lat long. it is easy if you are using autodesk mapguide studio. to add or
delete or anything, you can write your own script based on your developement
enviroment, or you can look at this site
http://data.mapguide.com/mapguide/devguide/index.php
ajid1980 wrote:
> Yap..update is when i want to change the data for example change a to b..
> Add and Delete also i want it.
> i have both data (spatial data and attribute data)
> So i wanna make a [Update][Add][Delete] data..
> Here example i converted it to Excel file.. for your reference.That a many
> more file.. :)  http://www.nabble.com/file/p21011068/sample.xls sample.xls
View this message in context: http://www.nabble.com/Datasource-Connection-*.sdf-%28Add%2CDelete%2CUpdate-and-Edit%29-tp21010132p21026727.html
