[mapguide-users] Show Multiple Properties for selection
Steve G steve.golden at morganhill.ca.gov
Tue Dec 16 12:03:22 EST 2008
I am using MG 2.0.  Using MapGuide Studio 2009 I've made a data connection
using the ODBC connection FDO (Connect via a DNS, connected to SQL Server
database).  The connection works (I am having some performance issues, but
that belongs in another post).  Next, I've joined this data using a
one-to-many join with a SHP file (table from the shp file is the primary and
data in the database is secondary).  The join seems to work ok.  However,
when I use the standard Select tool, the properties pane will only show one
of the records in the database, I believe the first entry.  I want to
display all of the records in the joined table.
Does anyone know how I can display multiple records in the properties pane?
I am using the standard ajax viewer.  Perhaps there is something to change
in the "ajaxmappane.templ" file?  I've possibly found some code around line
2582 that perhaps can be manipulated?  Sorry, I am not much of a programmer,
so any assistance would be greatly appreciated.
Thanks,
Steve
View this message in context: http://www.nabble.com/Show-Multiple-Properties-for-selection-tp21037197p21037197.html
