[mapguide-users] SDF convertion question
Jackie Ng jumpinjackie at gmail.com
Thu Dec 18 18:00:55 EST 2008
Try wrapping your connection string property in double quotes.
- Jackie
Moog wrote:
> Hi Jackie,
> i download FDO Toolbox, but i can't connect to my .txt file.
> I've configured the odbc connection, but when i try to make a connection
> with the driver it fails.
> my original connection string was
> Driver={Microsoft Text Driver (*.txt;
> *.csv)};Dbq=D:\Sample\txt;Extensions=asc,csv,tab,txt;
> but because of comma delimiter i got to change it for
> (*.txt)};Dbq=D:\Sample\txt;Extensions=asc,csv,tab,txt;
> but dbq and extensions are invalid connection properties for FDO toolbox.
> So i just leave the driver and i get this message
> http://www.nabble.com/file/p21080382/error.jpg
> Thanks
> Jackie C. Ng wrote:
>> You could try using FDO Toolbox (http://fdotoolbox.googlecode.com)
>> connecting
>> to the text file via the ODBC Provider (see examples here:
>> http://www.connectionstrings.com/textfile) and bulk copy it to a new SDF.
>> I
>> haven't actually tried this approach myself, so your mileage may vary.
>> - Jackie
>> Moog wrote:
>>> Hi,
>>> I wonder if there's a way to create sdf3 files from a text file (SDF
>>> loader
>>> from mapguide 6.5 allows to create sdf files from text reading
>>> coordinates
>>> with a delimiter).
>>> Or ¿can i use sdf loader from 6.5 and then use map to export this sdf2
>>> into
>>> a sdf3?
>>> thanks
>>> View this message in context:
>>> http://www.nabble.com/SDF-convertion-question-tp21054445p21054445.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://n2.nabble.com/SDF-convertion-question-tp1668183p1670662.html
>> http://themapguyde.blogspot.com
>> http://www.linkedin.com/in/jackieng
> http://www.nabble.com/SDF-convertion-question-tp21054445p21080382.html
View this message in context: http://n2.nabble.com/SDF-convertion-question-tp1668183p1675217.html
