[mapguide-users] Zoom To Selection
padmini godavarthi
godavarthi.padmini at gmail.com
Fri Dec 19 04:55:11 EST 2008
Thanks for u rreply.
it works fine.when i query with parcel_id='1' it was selected on the map and
displays the attributes in the property window.But i want to zoom to that
parcel id on the map(like zoom to shape)
1)How is it possible?
Regards,
Padmini.
Nandorov wrote:
> featureService.SelectFeatures(parcelId, "GEOM_TABLE", nameQuery);
> i think you should use layer class name instead of layer name
> featureService.SelectFeatures(parcelId, YourLayer.GetFeatureClassName(),
> nameQuery);
> padmini godavarthi wrote:
>> Hi,
>> Iam using Mapguide Opensource 2.0 (with .net 2.0 +IIS 5.1)
>> I want to query the parcel_id and zoomed it on the map
>> may code is
>> NameValueCollection serverVars = Request.ServerVariables;
>> String strServerVars = "";
>> foreach (String str in serverVars.AllKeys)
>> strServerVars += "<br>" + str;
>> String platform = serverVars["SERVER_SOFTWARE"];
>> String queryStr = serverVars["QUERY_STRING"];
>> string queryStr1 = serverVars["Form"];
>> NameValueCollection requestParams = Request.HttpMethod == "POST" ?
>> Request.Form : Request.QueryString;
>> String sessionId = Request.QueryString["SESSION"];
>> //String sessionId = Request.QueryString["SESSION"]; ;
>> string realPath = Request.ServerVariables["APPL_PHYSICAL_PATH"];
>> String configPath = realPath + "webconfig.ini";
>> MapGuideApi.MgInitializeWebTier(configPath);
>> MgUserInformation userInfo = new MgUserInformation(sessionId);
>> MgSiteConnection siteConnection = new MgSiteConnection();
>> siteConnection.Open(userInfo);
>> MgResourceService resService =
>> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
>> MgFeatureService featureService =
>> (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
>> MgMap map = new MgMap();
>> map.Open(resService, "oramap");
>> MgFeatureQueryOptions nameQuery = new MgFeatureQueryOptions();
>> //nameQuery.SetFilter(ConfigurationManager.AppSettings["FieldToFilter"] +
>> "=" + Globals.gURLParam);
>> nameQuery.SetFilter("PARCEL_ID" + "=" + "670_111");
>> MgResourceIdentifier parcelId = new
>> MgResourceIdentifier("Library://Orasample/resora.FeatureSource");
>> MgFeatureReader featureReader =
>> //Highlight the query result on the map
>> MgSelection selection = new MgSelection(map);
>> MgLayer layer = (MgLayer)map.GetLayers().GetItem("GEOM_TABLE");
>> featureReader = featureService.SelectFeatures(parcelId,
>> selection.AddFeatures(layer, featureReader, 0);
>> String selectXML = selection.ToXml();
>> selection.Save(resService, "oramap");
>> Page.ClientScript.RegisterStartupScript(Page.GetType(), "test",
>> "select('" + selectXML + "');", true);
>> but i got an error at
>> MgFeatureReader featureReader = featureService.SelectFeatures(parcelId,
>> 1)can u plz tell me what do u man by faeture class name?
>> from where i will gt it?
>> Thanks and Regards,
>> Padmini.
View this message in context: http://www.nabble.com/Zoom-To-Selection-tp21070073p21088605.html
