[mapguide-users] What is Tile Map?
Zac Spitzer zac.spitzer at gmail.com
Fri Dec 19 07:11:08 EST 2008
On Fri, Dec 19, 2008 at 10:57 PM,  <nelyass.heglig at gnpoc.com> wrote:
> Sirs,
> Would you tell what are the deferences between Tile map and ordinary map
tiled maps are cached (unless otherwise configured)
> Which one has a greater performance?
tiled because of cachng
> What happen behind the seen with the data from the server and client sides?
I don't know what your asking here???
> Do all data format (sdf, shp, raster etc.) can be used in tile maps?
there is no difference here between tiled and dynamic maps
> Thanks in advance
> Nadir Elyass
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
