[mapguide-users] create a temporary !Mapdefinition and add a layer
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Dec 22 03:39:12 EST 2008
That is likely an Xml validation error.
It can occur if the Xsd has changed, or one of your attribute values are
invalid.
What does the MapGuide error log state?
(On windows, look in C:\Program
Files\MapGuideOpenSource2.0\Server\Logs\Error.log)
Regards, Kenneth Skovhede, GEOGRAF A/S
Arnaud De Groof skrev:
> Hi,
> According to the codes samples
> (http://trac.osgeo.org/mapguide/wiki/CodeSamples), I try to use the
> PHP code samples to add a layer to the initial map.
> I carried out the below code but it seems that
> "$resourceService->SetResource($sessionResourceId,
> $byteSource->GetReader(), null);" encounters an error in the code.
> *<?php*
> include "../../mapviewerphp/constants.php";
> include "../../mapviewerphp/common.php";
> // Initialize
> MgInitializeWebTier($webconfigFilePath);
> $args = ($_SERVER['REQUEST_METHOD'] == "POST") ? $_POST : $_GET;
> $sessionId = $args['SESSION'];
> $mapName = $args['MAPNAME'];
> $layerName1 = 'YYY';
> $userInfo = new MgUserInformation($sessionId);
> $siteConnection = new MgSiteConnection();
> $siteConnection->Open($userInfo);
> $resourceService = $siteConnection->CreateService(MgServiceType::ResourceService);
> $wl = "Library://XXX/XXX.WebLayout"; // TODO Constant!
> // Build a string pointing to the new layer in the Session
> $rlLayerResourceId = "Session:$sessionId//$layerName1.LayerDefinition";
> // Read the XML of the Library Map Definition
> $md ="Library://XXX/$mapName.MapDefinition";
> $mdResourceId = new MgResourceIdentifier($md);
> $mdReader = $resourceService->GetResourceContent($mdResourceId);
> $mdXml = $mdReader->ToString();
> $mdDomDoc = DOMDocument::loadXML($mdXml);
> // Create the MapLayer XML nodeset in the first position
> $targetNode = $mdDomDoc->getElementsByTagName("MapLayer")->item(0);
> $newNode = $targetNode->parentNode->insertBefore(new DOMElement("MapLayer"), $targetNode);
> $newNode->appendChild($mdDomDoc->createElement("Name", $layerName1));
> $newNode->appendChild($mdDomDoc->createElement("ResourceId", $rlLayerResourceId));
> $newNode->appendChild($mdDomDoc->createElement("Selectable", "false"));
> $newNode->appendChild($mdDomDoc->createElement("ShowInLegend", "false"));
> $newNode->appendChild($mdDomDoc->createElement("LegendLabel"));
> $newNode->appendChild($mdDomDoc->createElement("ExpandInLegend", "false"));
> $newNode->appendChild($mdDomDoc->createElement("Visible", "true"));
> $newNode->appendChild($mdDomDoc->createElement("Group"));
> // Write the XML out to form the Session Map Definition
> $updatedXml = $mdDomDoc->saveXML();
> $byteSource = new MgByteSource($updatedXml, strlen($updatedXml));
> // Create a web layout in the session to hold the updated version
> // from the library.
> $sessionMapName = $mdResourceId->GetName();
> $sessionWebLayout = "Session:$sessionId//$sessionMapName.WebLayout";
> $sessionResourceId = new MgResourceIdentifier($sessionWebLayout);
> // Write the updated web layout to the session.
> $resourceService->SetResource($sessionResourceId, $byteSource->GetReader(), null);
> // Redirect to the Ajax viewer pointing at the map at the desired coordinates.
> $redirectTo = "mapguide/mapviewerajax/?WEBLAYOUT=$sessionWebLayout&SESSION=$sessionId";
> $host = $_SERVER["HTTP_HOST"];
> $url = "http://$host/$redirectTo";
> // Redirect!
> header("Location: $url");
> exit;
> //Test
> $f = 'exemple.txt';
> $handle = fopen($f,"w");
> fwrite($handle, "test0: <".$sessionId.">\r\ntest1 :<".$wl.">\r\ntest2 :<".$rlLayerResourceId.">\r\ntest3 :<".$md.">\r\ntestxml :<".$mdXml.">\r\ntest4 :<".$layerName1.">\r\ntestxml1 :<".$updatedXml.">\r\ntest6 :<".$sessionMapName.">\r\ntest5 :<".$sessionWebLayout.">\r\ntest6 :<".$host.">\r\ntest7 :<".$redirectTo.">");
> fclose($handle);
> Please would you like to help me to resolve the following issue?
> Thanks,
> Arnaud De Groof
> E-MAIL DISCLAIMER*
> The present message may contain confidential and/or legally privileged
> information. If you are not the intended addressee and in case of a
> transmission error, please notify the sender immediately and destroy
> this E-mail. Disclosure, reproduction or distribution of this document
> and its possible attachments is strictly forbidden.
> SPACEBEL denies all liability for incomplete, improper, inaccurate,
> intercepted, (partly) destroyed, lost and/or belated transmission of
> the current information given that unencrypted electronic transmission
> cannot currently be guaranteed to be secure or error free.
> Upon request or in conformity with formal, contractual agreements, an
> originally signed hard copy will be sent to you to confirm the
> information contained in this E-mail.
> SPACEBEL denies all liability where E-mail is used for private use.
> SPACEBEL cannot be held responsible for possible viruses that might
> corrupt this message and/or your computer system.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081222/0ccbdb3d/attachment.html
