[mapguide-users] create a temporary !Mapdefinition and add a layer
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Dec 22 09:06:42 EST 2008
Hmm, that just means that the Xml itself is invalid.
This line:
$byteSource = new MgByteSource($updatedXml, strlen($updatedXml));
If you are using non-us characters, I would imagine that strlen returns
an invalid length.
You can use mb_strlen instead:
http://dk2.php.net/manual/en/function.mb-strlen.php
The encoding should be "utf8".
Regards, Kenneth Skovhede, GEOGRAF A/S
Arnaud De Groof skrev:
> The error log contains the following message:
> <2008-12-22T10:10:38>                          Administrator
>  Error: An exception occurred in the XML parser.
>  StackTrace:
>   - MgResourceServiceHandler.ProcessOperation line 80 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
>   - MgOpSetResource.Execute line 103 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\OpSetResource.cpp
>   - MgServerResourceService.SetResource line 713 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ServerResourceService.cpp
>   - MgRepositoryManager.SetResource line 867 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\RepositoryManager.cpp
>   - MgRepositoryManager.AddResource line 840 file
>   - MgResourceContentManager.AddResource line 183 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceContentManager.cpp
>   - MgResourceContentManager.PutDocument line 624 file
>   - MgResourceDefinitionManager.PutDocument line 554 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
>   - MgResourceDefinitionManager.ValidateDocument line 429 file
>   - MgResourceContentManager.ValidateDocument line 556 file
> Kind regards,
> Arnaud De Groof
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* lundi 22 décembre 2008 9:39
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] create a temporary !Mapdefinition and
> add a layer
> That is likely an Xml validation error.
> It can occur if the Xsd has changed, or one of your attribute values
> are invalid.
> What does the MapGuide error log state?
> (On windows, look in C:\Program
> Files\MapGuideOpenSource2.0\Server\Logs\Error.log)
> Hi,
> According to the codes samples
> (http://trac.osgeo.org/mapguide/wiki/CodeSamples), I try to use the
> PHP code samples to add a layer to the initial map.
> I carried out the below code but it seems that
> "$resourceService->SetResource($sessionResourceId,
> $byteSource->GetReader(), null);" encounters an error in the code.
>         *<?php*
> include "../../mapviewerphp/constants.php";
> include "../../mapviewerphp/common.php";
> // Initialize
>     MgInitializeWebTier($webconfigFilePath);
>     $args = ($_SERVER['REQUEST_METHOD'] == "POST") ? $_POST : $_GET;
>     $sessionId = $args['SESSION'];
>     $mapName = $args['MAPNAME'];
>     $layerName1 = 'YYY';
>     $userInfo = new MgUserInformation($sessionId);
>     $siteConnection = new MgSiteConnection();
>     $siteConnection->Open($userInfo);
>     $resourceService = $siteConnection->CreateService(MgServiceType::ResourceService);
>     $wl = "Library://XXX/XXX.WebLayout"; // TODO Constant!
> // Build a string pointing to the new layer in the Session
>     $rlLayerResourceId = "Session:$sessionId//$layerName1.LayerDefinition";
> // Read the XML of the Library Map Definition
>    $md ="Library://XXX/$mapName.MapDefinition";
>    $mdResourceId = new MgResourceIdentifier($md);
>    $mdReader = $resourceService->GetResourceContent($mdResourceId);
>    $mdXml = $mdReader->ToString();
>    $mdDomDoc = DOMDocument::loadXML($mdXml);
> // Create the MapLayer XML nodeset in the first position
>    $targetNode = $mdDomDoc->getElementsByTagName("MapLayer")->item(0);
>    $newNode = $targetNode->parentNode->insertBefore(new DOMElement("MapLayer"), $targetNode);
>    $newNode->appendChild($mdDomDoc->createElement("Name", $layerName1));
>    $newNode->appendChild($mdDomDoc->createElement("ResourceId", $rlLayerResourceId));
>    $newNode->appendChild($mdDomDoc->createElement("Selectable", "false"));
>    $newNode->appendChild($mdDomDoc->createElement("ShowInLegend", "false"));
>    $newNode->appendChild($mdDomDoc->createElement("LegendLabel"));
>    $newNode->appendChild($mdDomDoc->createElement("ExpandInLegend", "false"));
>    $newNode->appendChild($mdDomDoc->createElement("Visible", "true"));
>    $newNode->appendChild($mdDomDoc->createElement("Group"));
> // Write the XML out to form the Session Map Definition
>    $updatedXml = $mdDomDoc->saveXML();
> // Create a web layout in the session to hold the updated version
> // from the library.
>    $sessionMapName = $mdResourceId->GetName();
>    $sessionWebLayout = "Session:$sessionId//$sessionMapName.WebLayout";
>    $sessionResourceId = new MgResourceIdentifier($sessionWebLayout);
> // Write the updated web layout to the session.
>    $resourceService->SetResource($sessionResourceId, $byteSource->GetReader(), null);
> // Redirect to the Ajax viewer pointing at the map at the desired coordinates.
>    $redirectTo = "mapguide/mapviewerajax/?WEBLAYOUT=$sessionWebLayout&SESSION=$sessionId";
>    $host = $_SERVER["HTTP_HOST"];
>    $url = "http://$host/$redirectTo" <http://$host/$redirectTo>;
> // Redirect!
>    header("Location: $url");
>    exit;
> //Test
>    $f = 'exemple.txt';
>    $handle = fopen($f,"w");
>    fwrite($handle, "test0: <".$sessionId.">\r\ntest1 :<".$wl.">\r\ntest2 :<".$rlLayerResourceId.">\r\ntest3 :<".$md.">\r\ntestxml :<".$mdXml.">\r\ntest4 :<".$layerName1.">\r\ntestxml1 :<".$updatedXml.">\r\ntest6 :<".$sessionMapName.">\r\ntest5 :<".$sessionWebLayout.">\r\ntest6 :<".$host.">\r\ntest7 :<".$redirectTo.">");
>    fclose($handle);
> Please would you like to help me to resolve the following issue?
> Thanks,
> Arnaud De Groof
> ** size=2 width="100%" align=center> **
> **E-MAIL DISCLAIMER**
> The present message may contain confidential and/or legally privileged
> information. If you are not the intended addressee and in case of a
> transmission error, please notify the sender immediately and destroy
> this E-mail. Disclosure, reproduction or distribution of this document
> and its possible attachments is strictly forbidden.
> SPACEBEL denies all liability for incomplete, improper, inaccurate,
> intercepted, (partly) destroyed, lost and/or belated transmission of
> the current information given that unencrypted electronic transmission
> cannot currently be guaranteed to be secure or error free.
> Upon request or in conformity with formal, contractual agreements, an
> originally signed hard copy will be sent to you to confirm the
> information contained in this E-mail.
> SPACEBEL denies all liability where E-mail is used for private use.
> SPACEBEL cannot be held responsible for possible viruses that might
> corrupt this message and/or your computer system.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> E-MAIL DISCLAIMER*
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081222/85be2fce/attachment.html
