[mapguide-users] Fusion and .NET Development
Mark Pendergraft
markp at Meadgilman.com
Tue Dec 23 14:19:07 EST 2008
The equivalent functions in Fusion can all be found in
MapGuideViewerApi.js and MapGuide.js files in the ..\fusion\mapguide\
folder. Open those two files and you will see all the functions. I
believe the two you are looking for are:
getSessionID();
getMapName();
you could access them through
window.top.Fusion.getWidgetById('Map').getSessionID();
or you could add a reference to MapGuide.js in your index.html file and
then just call getSessionID();
note: if you are using IE, I had some problems adding a reference to
those 2 files due to there being a comma after the curly brace of the
last item in a list. I can point you to a post about this if need be.
-Mark Pendergraft
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of KeithC
Sent: Tuesday, December 23, 2008 8:10 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Fusion and .NET Development
Brian, thanks but I'm not sure you understood what I meant. I need to
get the
session ID, etc that has already been established by Fusion, at the
client
side.
With the AJAX viewer, using InvokeURL my aspx page is called and the
JavaScript loads and calls the GetSessionId() and GetMapName() methods
of
the MapFrame object to get the values client side. I need the equivalent
from Fusion but it doesn't seem to be readily accessible.
Once I have got those parameters client side, I'm fine.
Regards,
Keith
Berdel, Brian wrote:
> Something like this will work
> public string GetParameter(NameValueCollection parameters, string
name)
> string strval = parameters(name);
> if (strval == null) {
> return "";
> return strval.Trim();
> string mgSessionId = null;
> NameValueCollection parameters = default(NameValueCollection);
> if (System.Web.HttpContext.Current.Request.HttpMethod == "POST") {
> parameters = System.Web.HttpContext.Current.Request.Form;
> else {
> parameters =
System.Web.HttpContext.Current.Request.QueryString;
> string mapName = GetParameter(parameters, "MAPNAME");
> string session = GetParameter(parameters, "SESSION");
> Brian
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Tuesday, December 23, 2008 9:20 AM
> Thanks Brian.
> How do I get the session ID, etc from Fusion? I need to pass these to
> the
> backend.
> Regards,
> Keith
>> If you were successful with the regular Ajax viewer you can hook to
> the
>> task pane of fusion using the intitial url or use an invoke url
script
>> to access the .net pages via a new window or the task pane. The
> mapguide
>> webapi is still accessible in fusion.
>> Brian
>> Sent: Tuesday, December 23, 2008 8:23 AM
>> Subject: [mapguide-users] Fusion and .NET Development
>> What is the easiest way to hook .NET based App development into
> Fusion?
>> I
>> have an application that uses the web API in C# and I'd like to make
>> this
>> available in a flexible layout. I don't wish to rewrite the App in
> PHP.
>> I do
>> need to extract some parameters from the client side to send to the
>> server,
>> such as session ID, map name and web agent url, but it's not clear
how
>> to do
>> this.
>> Keith
>> View this message in context:
http://n2.nabble.com/Fusion-and-.NET-Development-tp1693730p1693730.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
http://n2.nabble.com/Fusion-and-.NET-Development-tp1693730p1693910.html
http://n2.nabble.com/Fusion-and-.NET-Development-tp1693730p1694289.html
