[mapguide-users] Debugging .NET Application
Berdel, Brian brian.berdel at mcmtrans.com
Fri Dec 26 09:04:50 EST 2008
Go to Tools (in VS) and select "attach to process" then attach to the
aspnet_wp.exe in visual studio.  Then open your website and you will be
able to debug.
Brian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Iniya
Sent: Wednesday, December 24, 2008 3:03 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Debugging .NET Application
I have mapguide application developed using .NET. This is a small
portion of
a larger .NET application.
The .NET application is setup as a solution with multiple projects to
work
with SVN.
I want to add my mapguide code to one of the projects in this solution.
How
can I debug the code if I run a solution with mapguide code added to one
of
the projects in VS2005?
the mapguide application works only when it is run as a website i.e
http://localhost/Mainwebapp/Mapguideapp/main.aspx. Anybody done this
before?
Thanks
Iniya
View this message in context:
http://www.nabble.com/Debugging-.NET-Application-tp21156943p21156943.htm
l
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
