[mapguide-users] Problems using concat for URL Parsing
Mauricio Villablanca mgvillablanca at yahoo.com
Tue Dec 30 01:04:50 EST 2008
Hi Jackie,
Thanks for your reply. I made that post quite some time ago and the problem was caused by an attribute change in the Oracle database.
Thanks.
--- On Thu, 12/25/08, Jackie Ng-2 (via Nabble) <ml-user+148234-1960950029 at n2.nabble.com> wrote:
From: Jackie Ng-2 (via Nabble) <ml-user+148234-1960950029 at n2.nabble.com>
Subject: Re: Problems using concat for URL Parsing
To: "Mauricio Villablanca" <mgvillablanca at yahoo.com>
Date: Thursday, December 25, 2008, 5:34 PM
If you var_dump($_GET) in your php script, do you get anything w/ the string attribute?
- Jackie
mauro1970 wrote:
I added to this code to a layer:
concat('../central_plant/sensors/send_Id.php?DeviceID=', concat("thermostat_id", concat('&DeviceType=', "coord_x")))
When Control clicking, Mapguide correctly sends out the attributes "thermostat_id" and "coord_x" (both of type integer) to a script that displays the variables DeviceID and DeviceType. However if I replace one of the attributes with another attribute of type string, nothing is displayed.
Any ideas as to why that happens?
This email is a reply to your post @ http://n2.nabble.com/Problems-using-concat-for-URL-Parsing-tp1814683p1814685.html
You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/Problems-using-concat-for-URL-Parsing-tp1814683p2091420.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081229/a416b0d4/attachment.html
