[mapguide-users] OS 1.1 and SQL Secondary Tables
Jackie Ng
jackie.ng at aecsystems.com.au
Mon Feb 4 17:48:19 EST 2008
If you use 1.2, you can read views from SQL Server. To my knowledge, to get
the same capability in 1.1, you would have to do some crazy configuration
hacking in the Feature Source which I don't think even works.
Please note that that SQL Server Provider is different from the ODBC
provider. The ODBC provider is for attribute data and/or point geometry.
Whereas SQL Server Provider is solely for geometries (all types). To my
knowledge, you can't read attribute data via SQL Server Provider.
- Jackie
SFriedrich wrote:
> Can I link a layer to an external SQL Server for attribute information? I
> am using OS and it's my understanding that the Autodesk FDO Provider for
> SQL is only available if you purchase Enterprise? I have tried the OSGeo
> FDO for ODBC and can connect - but I assume this provider does not support
> Views?
View this message in context: http://www.nabble.com/OS-1.1-and-SQL-Secondary-Tables-tp15276186s16610p15279533.html
