[mapguide-users] OGR and PostgreSQL...can't see data in table
Traian Stanev
traian.stanev at autodesk.com
Tue Feb 5 11:02:30 EST 2008
Is the name of the primary key for your table ogc_fid? If not, you will need to set an environment variable for the MG server process.
The environment variable is PGSQL_OGR_FID, as described here http://www.gdal.org/ogr/drv_pg.html
Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Maciej Skorczewski
> Sent: Tuesday, February 05, 2008 9:45 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] OGR and PostgreSQL...can't see data in table
> hi!
> I try to connect via ogr to postgresql database.
> i get connection , and see all table but can't see any data in table.
> i use MG 1.2 , Postgresql 8.2 , FDO 3.2.2.66
> what should i do? any ideas?
> maciek
> mapguide-users mailing list
